I just received my spec-u exhaust yesterday. I need to know if anyone else here has this exhaust for their dbl cab lb and have an issue with the mid-pipe muffler not fitting correctly because of the carrier bearing support bracket. It looks to me that the pipe needs to be a little longer on the flex side and a little shorter on the exit of the muffler to keep over all length. My mid-pipe muffler will touch the bracket if you install it like it should be to keep the pipes level and straight. Thanks for any help.
[/URL][/IMG]
