P0136 and P0138
Assuming it was a faulty O2 I replaced both rear O2 sensors. Drove about 15 miles and P0136 came back. Thoughts? The two codes have been set for a couple weeks. Any chance the ECU needs to relearn having a operational O2 sensor. And for those that missed my last thread about this I am also running the URD O2 sim.
Anyone have any suggestions? No visible exhaust leak or break in a wire?
ntinhri
I recently had a issue with sim, after some testing, gadget swapped it and no codes. I had a issue with water getting in connectors. I would see if you can test with out sim and what codes your throwing. THen go from there. Call URD
P05X
"Wicked Pissah"
I know whats wrong its time for you to buy my x. :top:
kwigs160966
There is a relay in the fuse panel heater relay I believe. Could have burnt out. Also gadget once said that the ECM uses all four sensors to check against each other. I replaced three of my sensors before it went away.
