Good used engine
Gators Taco
<a . href="http://www.xr-underground.com/forum/sho
The oil burner is bad news. Using a quart for a tank of gas. Compression good on all 6. Need the heads rebuild ( 4000.00) or new from Toyota (1600.00) a piece. My first Toyota and it will be my last one.
Can you identify what cylinder is giving you trouble?
If it is just a valve stem seal and you can identify the cylinder it should be a not so hard fix.
KrazyIvan
Did you happen to also do a leak down test? That can be more helpful than just compression.
Gators Taco
Compression is good on all 6 ( 202 to210). He thinks the valve guides are leaking to. I know the seals need to be replace. If I add oil when cold and start the engine, I get a puff of blue smoke but never after.
Slywhitty
"Midget Magnet"
Thought you were gonna do a LS swap. Guess not anymore
Gators Taco
Not sure yet. Have to same some money. Being retired, funds are limited. Not sure if I'll go back to work driving a truck for the summer. Still looking into that swap.
Gators Taco
I'll check them out. TKS.
I'll swap you my built motor strait up, come take a listen and let me know. My truck is getting traded in so a Little some is ok by me..
Tunedx
Buy my motor so I can get my ls swap under way..
Gators Taco
Call me, maybe we can help each other achieve what we want
