You have 3 options that you could take
1. Run your stock coils
2. Use a spacer with your ss coils which can be found at APR(part is not listed ontheir site you would have to call) or a 4x4 store
3. Sell your ss drop coils and get the stock height coils from ss that will have the stiffer spring rate.
If you just ran your ss coils with the djm you would be dropping the front almost 5 inches which just may lay your front skirt on the ground!
