Dyno sheet
Hard Taco
Formerly Known As "Sn3akrs"
Forgot to post this on here I'm. Usually on Facebook forum
Hard Taco
Mods include
Dtlt headers
Afe 3" cat back
Urd intake
Urd pulley
A little on the lean side, but a very nice result!!
Hard Taco
Yeah I know I just got the Urd fuel pump hopefully that fixes that issue
Very nice numbers! Which pulley do you have installed?
Are you on the TRD reflash only?
How many miles does your truck have?
Also, I know it is asking a lot, but you think you could get another dyno after the new fuel pump is installed, showing the AFR again? It would be terrific for before and after comparisons to show a difference.
Hard Taco
It's the stealth pulley, I have 12k miles on truck, and yes trd re flash only. I gonna try and get another pull
XMPLRY808
How much boost were you seeing with the upgraded pulley?
XMPLRY808
Sorry I ment total boost? I kno climate matters so was wondering how much boost were you making to make that much power and what gear you use on the dyno.. And also did you do the fpr mod? Thanks
Hard Taco
About 7psi in normal weather. 8psi in winter. No fpr mod I did it and kept getting cel. I did the fuel pump. 4th gear dyno pull
iniazy
That is seriouly impressive. I didn't think TRD SC would make more than 300 WHP. It is rated from Toyota to make 305 on the crank.
All of the accessories which complement the boost. Helps it breathe so much better. :top:
