I'm not actually fast, I needed this one to be fixed quick, so I didn't do it myself, I took it to a shop to be done. They work all day long and have nothing else to do, so they finished it fast. It is now being my daily driver, so I can't keep it out of service for long.
I replaced my timing chain cover and my Fortuner is back on line. I have a theory why this happened. I think my previous mistakes when I installed the SC the first time slightly distorted the drive pulley of the supercharger, which caused it to not revolve perfectly circular. Several years ago when I did the installation for the first time, I did not torque down the crank shaft pulley bolt properly. The SC drive belt is held on the crank shaft pulley using that bolt. I didn't know how to torque it correctly, because it is an automatic and I didn't know how to hold the engine from spinning. So when I drove the car out for the first time to test it, the supercharger belt loosened the bolt and the drive pulley, and the pulley was banging around between the bolt and crankshaft pulley as the engine was running, so that probably distorted the center hold a bit, which caused it to not sit perfectly centered. So there is a slight movement that is causing the supercharger belt to vibrate right after it exits the drive pulley. Plus, I had the belt tensioned really tight, so this and that caused excessive strain on the pulley mount.
I have kept the belt looser than last time, which still seems to be adequately tensioned, no SC slippage. Hopefully this will not happen again. If it does happen again, I'll order another pulley from Alpine.
I looked at various Supercharger vendors, other than URD, and many of them use a static tensioner, so that should not cause a problem if things are done correctly.
I'm optimistic it will not happen again. First time I installed it I used it for about 10,000 KM before the engine broke, and nothing happened to the mount, and the pulley was suffering from the same issue, as it is still the same pulley.
Some pictures:
The timing chain cover, with a hole in it:
I got it cleaned up and washed:
I'm going to glue on the broken piece with EPoxy then I'm going to hang it in my workshop wall and use it as a tools rack. For good ol times sake.
About the MAF Elimination mode, I really had to use it, because my MAF wasn't giving a consistent reading to the ECU, so my AFR would go all over the place if I do anything sudden, like accelerate suddenly while cruising. This is why I had to go for this mode. Now it is very consistent and linear, and drives really nice like factory. I still have minor issues at gear shifts, as the gear upshifts during hard acceleration, say from second to third, the AFR gets too rich for a split of a second before it goes back to normal, which is slightly affecting my acceleration. I think the bypass valve is venting the excess air out, but the injectors and ECU don't know it yet because boost has not changed, since it is relying on MAP not MAF. Not sure how to fix that. And I still have that annoying starter problem, which I'm suspecting is caused by the replacement harness, cuz it only started showing up after I replaced the harness.
