XR-Underground » XR-Underground.com » XRU's TOP RIDES » November 2011 : Torspd's 2006 BSP 4x4: HONORARY TROTM
XRU's TOP RIDES The Hottest X-Runners, hand picked by XRU
Closed Thread
Thread Tools Search this Thread Display Modes
  #1
Old 11-01-2011, 06:27 PM
NHXRUNNER's Avatar
NHXRUNNER Offline
"New Hampster"
iTrader Rating: 3
2007, Black Sand Pearl
Mods: 20" Black Boss 335s|Sittin Sic Performance Drop|TRD CAI|TRD SS|LS 6K White Halo Projectors|HVM 6K Fogs|BHLM w/Straight Eyelids|FLM|Tinted Tails & 3rd|SS Performance Muffler|Gaylord Speedsturr Wing|S2K Antenna|C2C Hood Struts|Alpine IVA-W205 6.5"|Alpine SPR-176A (rear)|Alpine SPX-17REF (front)|Alpine SWR-1222D (x2)|Alpine MRP-M850|Alpine MRA-F350|Suede Enclosure w/ Amp Rack|RAAMAT|Weathertech|Denso Iridium plugs|Redline MT-90|Redline 75W90|
November 2011 : HONORARY TOP RIDE
Torspd's 2006 Black Sand Pearl 4x4 Access Cab
In The Beginning:
Since I was a little boy I have always dreamed of having a lifted Toyota. In part because during hurricane Alicia we were stranded by flood water, and a friendly stranger in his lifted truck picked us up, fording through the deep water, to take us home. And that my mom would take me off-roading/mudding with her brothers in their early '80s Toyota trucks. Well in February of '06 it was time. I went to the dealer and with what features of a Tacoma that I wanted. V6, 4x4, Access Cab, SR5, 6 Speed, non TRD. Being that there were none like that in Texas or any of the states around it, my truck was put to order to be made. Within two months I had a ProComp 6 inch lift and 35" mud tires. Off-roaded at Spring Creek nearly every chance I could. As a by product, parts had to be replace, and thath is how I became a member on XRU. I met a member at the dealership. His screen name is DreamMaker.
Being torn between off-roading and performance, and how incredibly strong the internet peer pressure was from this site, lol, the performance modding started.....which was the end of one phase, and the metamorphosis of the current state......I have always followed the motto of form follows function. This form functions much better in its new arena.
Engine:
] CP Pistons (Coated)
] Pauter Rods
] ARP Head Studs
] Ported and Polished Heads (By LC Engineering)
] Dual Valve Springs w/Titanium Retainers
] Stainless Steel Valves
] Cometic Head Gaskets
] Lower End Assembled by LC Engineering
] Tomei Large Diaphragm Fuel Pressure Regulator w/Tomei Fuel Rail Adapter
] Injector Dynamics ID1000 Injectors
] Aeromotive Stealth 340 LPH Intank Fuel Pump
] KillerGlass Upper Radiator Hose
] First Prototype Intake Manifold Spacer (Idea by me and Designed by Coupe)
] Modified Doug Thorley Long Tube Header w/ V-Band Flange(Driver Side)
] Custom Front Mount Turbo (Fabricated by myself and PowerFab Auto)
] ProEFI's Pro128 ECU w/Fuel Pressure Sensor, AFR Sensor, 5 BAR MAP Sensor
] Greddy ProFecB II Electronic Boost Controller
] Top Fuel Oil Catch Can
] NST Water Pump Pulley
] 160* LS1 Thermostat
Driveline:
] Custom One Piece Drive Shaft
] Driveshaft Loop
] SPEC Stage 3+ Clutch
] 3.73 Gearing (Front and Rear)
] Calvert Racing Caltrac Traction Bars
Interior:
] Defi Racer 52mm Electronic Boost Gauge
] Innovate LC-1 AFR Gauge
] Scangauge II
] TRD Floor Mats
] Tacoma Sill Protectors
Exterior:
] Centerline Mojave 20x9.5 w/ +19 offset Powdercoated Matte Black
] Nitto Invo 275/40 R20
] TRD Lug Nuts
] Black Headlight Mod
] Blacked out Toyota Emblem in Grill
] Rotora 6 Piston BBK w/Stainless Steel Brake lines
] VIS Carbon Fiber Hood
Suspension:
] QA1 Coilovers (Up Front)
] Eibach Coils (600 PPI)
] Tundra Racing Rear Axle Drop/Flip Kit
] XR Bilstein Rear Shocks
Future Modifications:
] Icon Billet Aluminum Adjustable Upper Control Arms
] King Racing Coil Overs and Rear Shocks
] Custom Intake Manifold by Beck Racing Intakes
] Ron Davis Custom Radiator
] Block Sleeved by Darton Sleeves
] ARP Main Studs
] Addco Rear Sway Bar
Congratulations Mark and great work on the truck!
__________________
~Matt
  #2
Old 11-01-2011, 06:31 PM
1GRracer's Avatar
1GRracer Offline
"Pete"
iTrader Rating: 0
2006 Toyota 4Runner 2wd "Lucario"
Mods: Engine - AFE stage 2, APR X1, URD fuel pump, NST intake manifold spacer, Denso IKH20, 1 5/8 DT Long Tubes, URD Y, APR fuel rail. Suspension - Addco front and rear sway bars, TRD FJ shocks front and rear, ES rear track rod bushings. Brakes - TRD pads, VSC defeat, Stoptech ss lines. Interior - Autometer Cobalt oil psi and temp gauges, AEM AFR.
Woot Congrats Mark!!!Well deserved.
__________________
#448 Lucario
  #3
Old 11-01-2011, 06:33 PM
Coupe's Avatar
Coupe Offline
XRU Overdosed
iTrader Rating: 72
2008 Radiant Red Baby!
Mods: TRD Blower, Coupe 7 1/2 qt oil pan, Stern ST-1 wheels, SS drop, SS sways, QA1, TRD intake w/ plexiglas cover, T56 Magnum (yeah baby!), Coupe shifter, Big tube long tubes, URD 3" cat back, All of NST pullies, MX upper/lower grille, BHLM, tinted tails, Gentex mirror, leather interior, APR X-1, URD fuel pump upgrade, rear spoiler, Nexus gages, etc.
Congrats Mark,
You should get it on engine count alone!
__________________
  #4
Old 11-01-2011, 06:35 PM
Fisherman's Avatar
Fisherman Offline
2nd Gear Member
iTrader Rating: 0
06 BSP
Mods: TRD BBK, TRD CAI, TRD S/S, TRD shift knob, DTLT, 18" Magnaflow, 2 10in jl subs, Bravo indash dvd, OBX pedals, Craven Speed stubby, Black powdercoated rims, LS 6k hid headlights
congrats! love the hard work put into your truck.
  #5
Old 11-01-2011, 06:41 PM
mixplate_xr's Avatar
mixplate_xr Offline
XRU Junkie
iTrader Rating: 1
2007 SWB
Mods: RGM, FLM, Morimoto Mini D2S Retros, BSP/SMOKE Tinted Taillights/3RD Brake Light, SS W/3INCH REAR, QA1s, WeatherTech Vent Visors, WeatherTech Digifit Floormats, Kenwood DDX719, 2 RF HE Punch 12s, aFe Stage 2 SI, NST Crank Pulley, DTLT Headers, SpinTech Super Pro Street Exhaust, URD SS W/Coupe Arm, 18x9.5 White XXR 522, Viper 5901
congrats and great work on the truck.
__________________
the best things in life aren't things
  #6
Old 11-01-2011, 06:42 PM
BSP06XRU's Avatar
BSP06XRU Offline
"Official XRU Photoshop Master"
iTrader Rating: 7
Mods: Never enough... but my bank account and wife says it is!
Awesome truck, Mark! Keep up the good work (and take pics while you're at it!)!
__________________
--------------- IN MEMORIAM JOHN MICHAEL JECKOT AKA MURDERFACE 1973-2013 ---------------
  #7
Old 11-01-2011, 06:54 PM
Rat Rod's Avatar
Rat Rod Offline
"Blade"
iTrader Rating: 4
good job bro congrats very well deserved
__________________
Founder of the Poptart warrior's
  #8
Old 11-01-2011, 07:08 PM
butters607's Avatar
butters607 Offline
"Bonifidegreasemonkey"
iTrader Rating: 2
08, candy blue!
Mods: UCON EMS , urd track bar, DT long tubes, ebc yellows w/brake motive drilled and slotted, chromed stock rims, 8k hids,redline mt-90 tranny fluid, NST Intake manifold spacer, black altezza tails, urd TOB tsk45, sitting sic track ready kit and qa1's, custom coupe single din triple guage holder, innovative blue afr guage, Butters607 oil cooler mod w/greddy sandwich plate, URD y pipe, 3" afe catback exhaust, walboro 255 fuel pump, URD MK3 stage 3, HKS blow off valve! coupe chopped shifter 8 1/4, 451RWHP 402rwtq custom oil cooler with e-fan XII track ready w/
god damn god damn oh yea this is one sexy monster and keeps up with rousch mustangs saw it with ma own eyes!!!!!
__________________
mk3'd dont be ricing around my town!
450 rwhp & 402ft tq
  #9
Old 11-01-2011, 07:26 PM
ICEMAN's Avatar
ICEMAN Offline
"I drive in the dirt"
iTrader Rating: 1
2005, SWB
Mods: ICEBABY1, born 09/03/08. ICEBABY2, born 05/05/10.
Congrats man....I remember getting a ride in it when it was lifted. I was impressed then!
__________________
  #10
hottacoX's Avatar
hottacoX Offline
XRU Overdosed
iTrader Rating: 3
2006, Rarely Red
Mods: TRD CAI w/Coupe cover | NST CR/WP/ALT | NST Manifold spacer | Street Star Rad hoses | URD SS w/Coupe 8.5" shifter | XII Performance Drop | QA1 | XII performance sways | URD trac bar | Gen2 DTLT | URD MAF Cal w/PNP harness | Redline Elite | BHLM | Cravenspeed Stubby | 6000k HID | Pioneer AVHP4200| 2 JBL 10's | Custom fiberglass box | Speedsturr Tonneau | VIS Carbon fiber hood | HVM CF rad/fuse box cover | HVM CF XR emblem|Weathertech Digifit | Tint 5%+20%| TXS Knocklite | Prosport EVO oil pressure| Innovate Wideband | Scangauge2 | TRD Oil+ Rad Cap(+10 HP)
Very nice truck man and much deserved, congrats man
Closed Thread
Tags
i<3megan fox, i<3toespd, rotm & not xrunner wtf?, turbo tacoma!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
2011 Grill on 2006 VaBchXRunner Exterior Modifications 5 07-06-2011 02:54 PM
November 2008 : XDsm's 2006 BSP K2 XRU's TOP RIDES 55 07-06-2009 01:17 AM
December 2008 : Super Werty's 2007 White 4x4 : HONORARY TROTM K2 XRU's TOP RIDES 65 02-10-2009 12:53 AM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
© 2006-2012 XR-Underground.com. All rights reserved.
XR-Underground.com is an independent Toyota enthusiast website specifically targeted toward X-Runner enthusiasts.
XR-Underground.com is not affiliated with Toyota Motor Sales, USA, Inc. The Toyota name and logo are trademarks owned by Toyota Motor Sales, USA, Inc.
