Will this Rim Fit My Xr?
K96732
I was planning on purchasing this rim but im not to sure if this will fit my xr.
the Staggered STR 601
Wheel description
Rim Diameter:19
Rim Width:19x8.5 , 19x9.5
Offset:+35 , +45
Hub Bore:73.1
Bolt Pattern:5x114.3
Number Of Bolts:5
please check it out. and help
AbunaiXR
I would go with a lower offset. +30 is stock. Those rims will sink into the fender. +12 on a 19x9.5 is flush from what i hear.
Grumpy
Yes you mount them on the truck but fitment will be horrible. If you must staggered the wheels, go with 8.5 +17 & 9.5 +25 combo. 9.5 +25 all the way around for best fitment.
K96732
what do you mean by my fitment will be horrible. ? and offset is recommended at +25 cause im planning on getting 19s on my rims. that is multispoke.
kayo808
If you get a higher offset rims its going to sink inside of the fenders to much. So most people would go with a lower offset so the rims would be either flush to the fender or stick out (if thats your thing) more from the fender
Workman3886
I got 19 x 9.5 +15 offset with 285 tires all the way around and I only stick out about a half of a inch, I love the way it looks, thanks to Grumpy because I didn't know what the hell I was looking for
K96732
how bout these rims: Stern ST8 Hypermesh II
Number of Bolts: 5 Rim Width: 8.5 Offset: +32 Rim Diameter: 19 Bolt Pattern: 5x114.3 Hub Bore: 73
WallasX
It will fit, but will not be flush with the fender. You need a much lower offset as stated above.
Grumpy
Thanks for the kind word Workman3886, glad I could help.
Got to see those Raijin in person last week, they look great. Really dig the concave face.
19x8.5 +20 is a better fit....but 19x9.5 +25 will get you even closer to being flush with the fenders.:top:
AbunaiXR
maybe youre just having a hard time understanding the offsets. dont worry, i had a hard time too.
+32 will have the mounting point 32mm away from the center of the rim. the further out your mounting point, the more your rim "sinks" in the fender well. The lower the offset, the more your rim will stick out.
The rims you listed would fit, but they would look like the stock fitment or worse.
