wolfpack_5150
Jangley
- Jan 13, 2012
- 303
- 17
after installing thorley longtubes, I noticed a ping/tin like sound to the engine bay......I ASSUME its just the headers, and want to know if anyone else has noticed the same.
Leaks up at the studs wont be easy to trace due to the normal racket of our trucks engine.....
NO, i did not use any RTV,
YES I did use new oem gaskets up top, and new URD gaskets at the collector/y pipe.
Yes I did use proper tq and pattern
YES I did retorque all the nuts/bolts after 2 heat cycles.
NO, the noise is not heat/cold dependent
these are the second version of long tubes with the 2 bungs per header..... the single primary is capped, and I am using the collector bung for my 02 sensor.
also installed URD y pipe.......................and the 3" exhaust (URD MK2)...............and the exhaust is soo raspy its hard to tell under load from insde the truck whats making the most annoying sound.
