TSB: Oil Leak From Front Timing Cover '05-'08
s/chargedxrunner06
Toyota Master Tech
Thought I would add this to the list of TSBs, mine leaked at 1000 miles and we have done a lot of these on the 1GR-FE for the timing chain cover leak, the leak will start on the passenger side of the motor around the power steering pump between the timing cover and engine block.
ADMIN EDIT: added new TSB pages
Tapp
yeap..mine just started...going in tomm. to get it taken care of...
Thanks ArkansasX for the heads up on it/as well as Glen from TTC for pointing it out to me..:top:
ntinhri
anyone else you want to thank? your mom, dad, your hot wife, your dog, ect???lol
Now I need to check for this leak!!
dak-rt-2a-XR
id like to thank the academy, all my friends, and all those who i dont know and have nothing to do with this
My68ur8trd
I just found this yesterday. I will have it looked at the next time its in :top:
Justin
eltus
good stuff. that will be something to keep in mind when I get back!
jimx
will the toyota extended warranty cover this? mine started leaking after the nst pully installed.
Just had my X checked by the dealer and they confirmed my leak was covered by this TSB.
I have to go back in next Monday for them to pull the motor and fix it! :thumpdown:
At least they'll give me a loaner while it's being done.
ICEMAN
"I drive in the dirt"
I wish I was still under warranty to get this covered.
Generation-X
Anyone have an actual shot of where this leak is supposed to be at. Mine is leaking from near there and would be awesome if its related lol
Found a pic of the cover. Mines leaking from near where the curve is to the left of the cover?
XRnRElite77
the leak starts where the PS pump mounts to the block, its too tight and causes the TC cover to be pryed away from the block, its retarted that TOYOTA mech dont fix the problem instead of the issue. they fix the leak but not what causes it. the TSB says nothing about replacing the PS pump or milling the bracket. :thumbdown:
red - issue with why it leaks, top bolt location needs to be about 1/16 thinner
blue - where the leak accurs.
No pics, but the TSB say it's "where Bank 1 cylinder head, engine block, and timing cover meet."
When facing your engine, it's on your left (passenger side). See the diagram on page 4 of the TSB in the first post.
Mine was grimy behind and below the pulley on the vane pump assembly. If you crawn under your truck, you can look up and see how dirty it is up there!
Don't know if I can get a good shot of it, but I'll try...
Edit:
Front Top View:
Bottom Side View:
Generation-X
Yep thanks guys. Thats where my issue is too. Guess im needing a call to the dealership tom and maybe even a rental vehicle, ill ask for something sporty if I can get it LOL
The TBS says the repair is covered under the Toyota Powertrain Warranty (60 months or 60,000 miles). Don't know if extended warranty covers it. Good luck! :top:
Generation-X
Mine hasnt topped 60K yet so im hoping to get in soon. Still at like 58k
