FAQ: Complete X-Runner Specs
XrunnIT
Official specs for the Toyota X-Runner. :top:
ENGINE
4.0-liter DOHC EFI V6,
24-valve aluminum block with aluminum alloy head with VVT-i
236 hp @ 5,200 rpm
266 lb-ft @ 3,800 rpm
Bore & Stroke: 3.70 x 3.74
Displacement: 3,956 cc
Compression Ratio: 10.0:1
Ignition System: DIS (Direct)
Fuel System: EFI
Recommended Fuel: 91-oct
Emissions: LEV-II
DRIVETRAIN
6-speed manual overdrive (V6)
Drive System Type: 4x2 front engine with rear-wheel drive
RATIOS:
* 1st 4.17
* 2nd 2.19
* 3rd 1.49
* 4th 1.19
* 5th 1.00
* 6th 0.85
* Reverse 3.61
* Final Gear 3.153
WHEELS AND TIRES
18 x 8 Alloy
Bridgestone Potenza RE050 255/45/ZR18
Bolt pattern is 5x4.5", 5x114.3mm
Lug nut size is 12mm x 1.50
Offset is +30mm.
Center Bore is 60mm
Wheel weight is 31lbs - 32lbs
Tire weight is 29lbs
SUSPENSION
Front: Coil spring independent double wishbone with gas-filled shock absorbers (4x2 – low mount)
Rear: Leaf spring rigid suspension
Front Stabilizer Bar Diameter (inches): 1.18
Rear Stabilizer Bar Diameter (inches): 0.98
BRAKES
Power-assisted four-wheel Anti-lock Brake System (ABS) with Brake Assist (BA) and Electronic Braking Distribution (EBD)
Front: Ventilated Disc
Front Diameter: 10.83-inches
Front Swept Area: 56.75 square inches
Rear: Leading-Trailing Drum
Rear Diameter: 10-inches
Rear Swept Area: 61.82 square inches
Parking Brake: Stick Type
STEERING
Ratio: 17.4
Turns (lock to lock): 3.43 turns
Turning Circle (ft.): 42.0
CAPACITY
Fuel Tank: 21 gallons
Cooling System (quarts): 10.3
Engine Oil (quarts): 4.4 w/o filter change, 4.8 w/filter change
EXTERIOR DIMENSIONS
Overall Height: 65.2
Overall Width: 74.0
Overall Length: 208.1
Wheelbase: 127.2
Inside Bed Length: 73.5
Inside Bed Depth: 18.0
Inside Bed Width-
At Tailgate: 52.9
At C-Channel: 56.7
Between Wheel wells: 41.5
Front Track/Rear Track: 62.2/62.2
Running Ground Clearance: 7.5
Coefficient of Drag: 0.368
INTERIOR DIMENSIONS
Headroom (front/rear): 39.9/35.2
Legroom (front/rear): 41.7/28.2
Shoulder Room (front/rear): 57.7/57.7
Hip Room (front/rear): 53.6/53.6
Maximum Seating Capacity: 4
EPA ESTIMATED FUEL ECONOMY (mpg)
6-speed manual (V6): 15/19
VEHICLE MASS (lbs)
Curb Weight (man): 3,690
GVWR: 4600
Payload (man): 910
TOWING (lbs)
Towing Capacity: 3,500
Tongue Weight: 350
Gross Combined Weight Rating (GCWR): 7500
ANGLE OF APPROACH/DEPARTURE (degrees)
Approach: 19
Departure: 19
Break over angle: 15
PERFORMANCE (As tested by 3rd parties)
*Acceleration 0-60: 6.9 sec
*Quarter-mile elapsed time: 14.92 @ 93.10
600-ft slalom: 63.67 mph
Lateral Grip (200ft skidpad): 0.97G
*These times are listed as corrected times by Motor Trend, and not the actual times. Actual stock 1/4 times vary, most run low-mid 15's trapping 89-91mph.
is the towing capacity regarding the trailer hitch or putting a ball joint on the rear bumper
XrunnIT
From the bumper, in the specs they didn't have any specs for a trailer hitch. :thumpdown:
RJDoute
"My Salami Nipples Ooze Milk"
Sticky this is useful stuff. :top:
EDIT:
You're a moderator. Of course it's stickied. I'm going to go bury my head now. :top:
Grumpy
Awesome, lots of useful reference material.
Isn't our MPG 17/21?:dontknow:
TitanRattler813
source of info?
I usually either use MSN Autos or if I don't have the net, I dig through the manual.
XrunnIT
source of info?
This is from Toyota themselves, as the Official specs. I have the PDF doc that has the info for all the trims, so i parsed out just the XR stuff. :top:
TitanRattler813
cool :top: ... now my 18 mpg doesn't seem like I'm doing so bad. I just moved up to a higher percentile :laugh:
Like Grumpy asked, I always thought it was 17/21, but I'm more like 16/18
XrunnIT
I usually got between 15/18 with city/highway mix before my mods, then it went up to about 17/20. Then with the blower only one tank at it was about 16 (and that's with my foot in it all the time :biggrin:)
Grumpy
I regularly get high 19s (80% hwy), with the last tank came in at 20.44mpg. That's only because I'm in grandma mode breaking in my short block.
LOW AND BLOWN
I get 100 miles or a little more per hash mark on the fuel gage,which is about 19-20 mpg.
XrunnIT
We've already got a thread discussing gas mileage so lets keep this thread on topic with spec related conversation, and MPG in this thread --> Gas mileage
mad hatter
what about 0-60 and skid pad?
I've read that the 0-60 is 5.7 or something close and the skidpad is 1.9 Gs. Confirmation?
08x
for sum reason some of the info doesnt seem rite as in the oil capactiy is not rite at all i work at a toyota dealership and 4.4 quarts ona 4.0 v6 is low
blazinx
so i guess im doing it wrong by puting regular pump gas instead of mid grade?
XrunnIT
.97G as recorded by Toyota and TRD.
Updated first post with performance section. :top:
Tapp
so what do you think 0-60 is with the TRD blower??
