complete
Got a few small things I need to touch up, but it is generally done. I also added a rubber body-kit grommet to center part of the front skirt, to fill in for a piece I removed.
Something is still missing... and its the headlights, which I should get in a week or two. They will tie everything together, and it will look perfect.
I am also thinking of adding a red TOYOTA badge in the bottom right corner.
The main grill and lower bumper opening are secured with zip ties. The upper grill had 3 factory spots that worked. I added a few 45deg small door hinge brackets with some mounting tape, and zip tied to them.
The corner triangles are glued in with a two part, collision repair structural glue that I got from one of the body-shop guys at Heintz.
