clutch and TOB service bulliten
ddunbarxrunner
there is a new service bulliten as of november 22, on 2005 and up , under 60,000 covers clutch and TOB on 6speed manuals....i found out the hard way mine has 70,000 and i already put the CC clutch i got from urd in earlier this year and new TOB. but they finaly changed the clutch and TOB. cause the clutch springs were breaking and TOB was goin bad. my trucks in the shop now for a broken shift fork . should be back on the road monday
blackx-runner
"White Flash"
If you could get an actual TSB number that would be awesome. There has been talk about a TSB for some time, but no actual documentation from Toyota can be found. It seems toyota is aware of the problem and gave the dealerships the ok to swap out parts, some guys are getting taken care of and some guys are getting the shaft.
Anything you can give us, like a TSB number, or what it states on your work order from toyota that would be great.
T0LLPHR33
"Catwoman"
^ditto...would like to have the TSB printed in hand if I ever have to take my truck in for the clutch and/or TO bearing...:top:
Rat Rod
"Blade"
in hand would be a huge help as weell as the url for them to find it
TOB = throw out bearing? (pdf wont open on my comp)
Here's all six pages of the TSB:
Venomous_X
I only see that as a difficulty in clutch engagement, mine slips a bit in first and is a squeaky to bearing.....will this bulletin cover?
TRD-X
Now they know we are tired of the trans and clutch problems!! Maybe they will fix all the problems .:top:
And thanks for the post Cuz!!:rockon:
Venomous_X
i wont be covered....as it stands and i dont see anything about the throwout bearing
It only covers if u put it in gear and the truck goes nowhere:thumpdown: this is for clutch disc failure.
Oh well maybe nextime
Venomous_X
yeah, this is useless information for me.....I need the to bearing covered! I can live with tranny grind I mean i just would have to not shift in 5th above 2500 rpms....but the TO is pissing me off.
rios
i also need the TOB to be covered..
i was really hoping for this to pull through as i ground 3rd gear hard today and 3rd grinds every couple days.
thunder24685
I got all excited when i seen thread thought i was going to get the annoying squeak fixed
08x
wow it still pays liek shit gotta hate warranty times 2.7 hrs for a clutch when under warranty when its customer pay u can get up to 10 hrs gotta love warranty but i havent seen any tsb on the toyota tech stream sight ill keep and eye out on it thoe
cam08
Just had my TOB replaced under extended warranty - had 38k miles about a month ago. Tech said it looked rusted. Still had to pay the deductible but at least the whinning has stopped.
thunder24685
talked to my sevice rep wed he told me it was coverd under the 60,000 mi wrnty
give it 30days it will be back had mine replaced twice waitng on weather to clear up so i can get it done again
cam08
Funny you say that- the tech said it will probably do it again!
