Yeah I've been spoiled by working on a lift for so many years. I avoid doing anything on the ground if at all possible. I spend too much time hunched over in the garage working on the bikes that I would rather not do it on the truck.
Current mods on the truck
URD Maf Caf, DTLT, Intake Manifold Spacer, Gen 1 TRD intake, 3in Cat back, StopTech BBK, URD SS, BHLM, Stubby antenna, a bunch of stereo stuff.
Mods to be installed before or around the same time as the Turbo kit (most of which I already have or is in the mail on the way)
URD stage 3 clutch & upgraded throwout bearing
UCON, w/tstat, cam gears, etc
61lb injectors
URD fuel pump kit with Walboro 255
70mm throttle body w/URD adaptor (still trying to find a decent deal on the damn TB)
Innovative Wide band
Boost/vacuum gauge
New Denso sprark plugs
Vibrant 3in bottle style resonator after the downpipe, to a QTP electronic Cutout, and also adding a Vibrant ultra Quiet resonator behind the cutout.
GReddy Oil filter block adaptor
Manual boost controller
and a probably a few other things that I'm forgetting. I'll be installing most of the items one by one to prep for the turbo kit install over the next few weeks. Hopefully this week I can find time to install the fuel pump kit and maybe the UCON. I'll try to keep you guys updated with the progress.
