Stability control
Ahmad
turned off traction in my 2009 x runner and every time I try to kick it out stability steps in and kills the power, does the same thing when I hold the traction control button and fully turn off traction the stability still kicks in. Is there a way to turn off the stability as well so I have full control over the drive?
Try this:
With the engine running, stopped and foot on the brake:
1. Push and hold the button until the lights come on, release the button
2. Push and hold the button for 4 seconds. The lights should blink or do something, or more lights should come on, release
3. Push and hold the button for 4 seconds and release.
If it works the same as the 4x4 Toyotas, now everything should be turned off.
Push and hold the VSC button for about 5 seconds while stopped. The TRAC off light will come on but I believe the system still lurks in the background. It is possible to pull an ABS fuse to disable everything but remember that you have an open diff so it isn't going to slide around like you think it will.
20150611_081633-jpg.719353
Ahmad
Try this:
Ahmad
I know it’s open diff but even when I hold it and have traction off the whole time stability still steps in
On my 07 with VSC, I hit the button once and it gets me to auto lsd, then while on the brake hold the button again for 4-5 seconds and everything is off...
Nashman
to bad you can not turn off auto lsd bull shit
omgwtfbbq!
....you can though? Just hold the button longer. Pressing it once is no traction control below 35 but auto lsd still active, press and hold and everything turns off.
Nashman
by law after not sure what year think it was 2008 it was a rule that stability control can not be turned off after a certon speed it will re activate thini k it is over 40 km at the front tires
I've never heard such a thing....remember where you heard that?
Nashman
mechanic teacher that taught me a long time ago i am not certon on the year but it's around that time. same reason all cars look alike now because of safety standers on hood hight ect
XMPLRY808
I have a 2015 and I can run mine off with no problem. Just hold down the button
autobodyX
yaw control still remains
Yes and as soon as you push it having some fun wam the fun natzi kicks back on and tried to kill you.
Only way to stop it is a Ecu fault. System goes down if the check engine light is on.
