just put in my sc and now i think my motor is f**ked
x-runner808
so just put in my sc two days ago, and was driving home last night going about 55-60.tried to give it some gas and felt like my truck had no no power so i tried to rev it up and was like it was stock. then as it got up to 4000 rpm it made a clacking sound so i pulled over and checked if the coil packs where good check the injectors and seemed fine. so towed it home. has any one had this just wondering?
any one know the problem??help plz
Kevin S.
does it start? What did you test on the coils and injectors? Maybe a Vacuum leak - do a leakdown test and see if it's getting proper vacuum.
x-runner808
yes it starts. the idle is ruff tho. 500-1200 rpm. i unplugged each coill and injector to see if one was dead but didnt seam like it. i did a rough run threw on vac lines didnt find any leaks .
Which blower? If TRD is the blower belt still on it?
urd mkII. yea the belt is on.
MplsX
I would start by checking your fuel pressure. Good luck.
Yardie
"The Jamaican"
Stupid question but I gotta ask, is it tuned yet or were you running without a tune?
x-runner808
has the apr x 1. i bought it from a guy that had it tuned. im running everything to what the guy had it to.
Clifford
because race truck
Sounds like my truck when it went into limp mode once. I reset the ecu and cleared my codes and never had another problem. Hope it's something simple like that for you.
Every truck requires a different tune..... Sounds like the x-1 needs to be tuned as its either going into a protection mode and shutting the truck down, or on the opposite end running really lean and cutting out.
Call urd tech support and have G's input!!
DO NOT DRIVE THE TRUCK WITHOUT TALKING TO URD...
x-runner808
yea will do tried to call g but he hasnt gotten back to me yet so waiting on that..
gonna go into that x1 when i get home
Clifford
because race truck
I think G may be stranded away from home due to the storm on the east coast. Try and be patient with him.
If you want pull the belt off the sc, unplug x-1, replace to injectors back to stock and see if your problem persists....
Basically return the truck to n/a by taking out the least amount of the sc that you can
nick_gz1
oh yea G went to SEMA and i think he drove cause his plane got cancelled so it might be a lil bit but im sure he will hit you up as soon as he hears.
Amo-cat3
I live in kihei and maybe i can help. I have xtune on my laptop and can probably load the basic supercharger map for you. I installed my charger myself with all mods and maybe can help. PM me and maybe can check you out on wednesday.
Whitebeauty
That what im talkin about.... Brotherly love baby!!....awesome u can help!:top:
URD Tech Support is OPEN.
877-8URDUSA x3
