Passenger Side Rattle
jeffxrunner07
I seem to have a rattle on the passenger side door. Every once in a while when I hit a bump, it sounds like the door is not closed properly. I was just wondering if any one else has experienced this? And if so, what the problem seemed to be.:hmmmm2:
JiNsEiGaNaI
I have this problem too, but never thought much of it! would like someone to answer this though!
and also when i angle over bumps n stuff, why it creaks so much? is that normal?
*IrunnIt*
Same thing here, cant figure out what it is, drives me crazy
JiNsEiGaNaI
ya i hear ya! i think that why i kinda just ignor it hoping it will go away!
jeffxrunner07
i will have to try that once i puul my truck out in the spring. will let you know if it works. seems like there is a lot of problems with this
triumphx
Its normal, just chassis flex. You have to remember we dont have a b-pillar which almost all vehicles do and would go between the 2 doors making everything more ridgid and reducing chassis flex.
bluedemon
chased mine down for a week, turned out to be the pipe on my K&N was turned and the airfilter was hitting the fender.... goodluck hope you get it figured out
Amo-cat3
Check your passenger side mirror. Give it a shake see if it's loose. I had to tighten mine up when I first got the truck. Pop the black triangle off and there's a single nut (maybe 10mm) and tighten a little.
