Limitless
- Feb 23, 2010
- 386
- 12
So on my way to work yesterday I find myself struggling to change gears near the end of my 30 mile commute. If I RPM match I can shift fairly easily but when I am stopped and want to try and switch to first or reverse or whatever, it fights me and wont let me go into gear. Its not grinding or anything its just not letting me go into gear. I drove it again today and its a little better at first when its cold but as it warms up it gets harder to change gears. What are everyones thoughts on this and has anyone experienced this before.
A couple notes, about 5000 miles ago I had the dealer put in a new URD TOB and it seems to work fine, but they did have to pull the tranny down to do it.
I also have a URD short shifter if that makes a difference.
Had the trans fluid checked and its still topped off. Was told it may be the clutch slave cyclinder (assuming we have one). I wouldn't think it was the clutch failing because I would think it would be slipping instead of the issue I have. Also, is there a coolant type system for the transmission oil, if so that may be the issue as well since it is more noticeable after driving for a bit.
Thanks for the input.
