Want to put Stock Suspension back on but think I'm missing some Parts
TommyXrunner
Alright so over the past couple years I've been trying to sell my truck but no one in my area is interested in a 2wd truck. Especially when it costs as much as a 4wd taco. So I've decided instead to keep my X but would like to put the stock suspension back on. My question is where can I find stock suspension parts? I have the stock shocks and springs but think I'm missing the stock U shaped brackets to take the drop blocks off the back. Maybe someone has some lying around? I know going to the dealer could cost me a fortune for these. Thanks!
kwigs160966
The rear u bolts you can pick up at any local parts store. What kind of drop are you running?
SgtBadA
Try rockauto.com they have all kinds of stuff for a reasonable price.
TommyXrunner
I have a XII drop springs in the front and 2" drop blocks in the rear. Also have some 3" drop blocks but truck dosn't drive very well with 3" blocks. bottoms out sometimes and you get a little wheel hop when you step on it around a corner
send me your drop kit and I will send you the factory equivalent back
TommyXrunner
I actually went and insured my truck today so I can't take the suspension apart and wait for parts but I'll have the drop kit up for sale as soon as I get around to swapping everything. Thanks though man
Rockauto has x runner front springs for 70 bucks a pair. Get them and a set of u bolts from an auto parts store and you're back to stock.
BigWhiteFrunkis
I just put my xii lowering kit on yesturday. I have everything you need. Let me know what youre looking for. I can sort it out and take pictures.
TommyXrunner
Thanks guys. I think I just need the U-Bolts for the rear. Still have the Springs. Only thing I can't remember is which spring goes on which side. One of the springs has a red marking on it
TommyXrunner
Found which spring goes on which side. Red mark on drivers side. Yellow mark on passenger side
AZ Sun Lover
Flip them upside down and put them side by side. The little taller one will go on the drivers side.
AZ
T4Z
Hey if you want local sale for your drop kit when you take it off give me a shout! I was in Kelowna yesterday!
TommyXrunner
I'll let you know as soon as I get around to swapping the suspension. I work in Vernon a lot. We can meet up there sometime after I've got all the parts off if you want. $200 for the full kit. I have 2" and 3" blocks if you want to go lower in the back but to warn you the ride is much better with the 2" blocks.
T4Z
Sounds good man! I am currently working in Vernon as well! Send me a message when you are ready, or need a hand with anything. Thanks!
TommyXrunner
For sure. I'll let you know as soon as its ready for you. Just need to find the right u-bolts for the rear suspension. Toyota dealer didn't know which bolts fit the X-Runner. I should be able to just measure them though
kwigs160966
1/2inch u bolt. 3 inches wide. And 8 inches long will work.
