KETCHUP
- Nov 1, 2007
- 11,665
- 3
TRD Ketchup:top:
cool, things to look forward to maybe!! :dontknow: :biggrin: :crinklehair:
SignUp Now!TRD Ketchup:top:
yea but any ideas why it kept it in like "launch mode" the whole way? like i kept trying to floor it and the check engine light just kept flashing....
That will be hard to determine with out analyzing a log - unless it was an engine guardian activation (which does activate upon launch control now and then but usually isn't a problem because the launch timer is typically less then the EG delay).
What was your launch timer set to when this happen?
Do you have a log?
not sure about the timer, G set it up for me. and thats a negative to the log :thumpdown: Thanks for the help though. do u want to see the file?
Can you copy and paste the current LC configs?
Depending on a lot of things, the bogging was most likely due to the timer in LC not expiring. While that timer is running there is a ton of timing retard which will kill power. Also depending on when that timer starts (mph setting). The timer doesn't start right away there is a bit of a delay.
Thanks XRunnit for the help. here is the info for you guys:
"LaunchMode(Mode)" 0
"LaunchTime1(s)" 3.000
"LaunchRpm(Rpm)" 3000
"LaunchVs1(Mph)" 10.0
"LaunchSpark1(BTDC)" -15.0
so how do i go about changing these settings and how do I change it on the USB or save it or open it ? lol sorry guys.....im a reh-tard when it comes to xtune, haven't ever had a chance to mess with it
"LaunchMode(Mode)" 1
"LaunchTime1(s)" 1.3
"LaunchRpm(Rpm)" 3800
"LaunchSpark1(BTDC)" -12.0
WWWWWWWWWWEEEEEEEEEEE :top:
how did that run for you? I think that would be too aggressive for a TRD boosted truck, being extremely torquey.
Can u trip the EG to come on if you give too much gas in LC before u pop the clutch?
