Jeremias
- Sep 19, 2007
- 1,311
- 4
I have been pretty busy but here it is.
- 3 tools: needle nose pliers, 14mm stubby wrench, 12mm stubby wrench.
- Go to local hardware store and buy a pack of adjustable chair feet.
- Cut 1/4 inches of thread off and straighten threads out.
1. Look under the dash at the bottom of the clutch pedal.
2. Remove the bright green spacer with needle nose pilers. Push pedal down to assist removal.
3. On the bottom of the clutch pedal there will be a black steel piston. On said piston there will be a 14mm square nut and a 12mm lock nut.
4. Loosten lock nut.
5. Push pedal towards top of truck (don't force), spin the square lock nut in a downward rotation until piston spins.
6. Tighten lock nut.
7. Install spacer with nut.
8. Enjoy!
8. Enjoy!
