SignUp Now!If I interpreted G's words of wisdom, I believe you can just order a shorter 6 rib belt and cut off a rib and install it with the stock pulleys. This would save 700$ and be a lot easier.
i have issues with slip with the 2.7
You don't nees to replace every pulley. Juat the sc and crank one.
your missing the point wilson more ribs = more surface area = less belt slip which means boost is more consistent
