Been working on these for a while now but been kinda busy to work on them alot. This project started out in the sumer and this is where I'm at now...
These are OEM Acura TL Bi Xenon Projectors purchased off of Ebay. Originally I was going for the TL/ZKW Clear lens combo but purchased the wrong ZKW Clear lens... The ZKW's are about 500 for a set of projectors, but you just want to use the lens, so spending 500 for lens is out of the question right now. For now I'll be sticking with the stock fresneled lens the TL's came with.
Shot with Canon PowerShot SD630 at 2007-08-07
Tested it out one night and had amazing results! These weren't mounted yet or anything, just hooked the ballasts up to my battery to power them up
Shot with Canon PowerShot SD630 at 2007-08-08
The wall is about a good 200+ ft. away
For mounting I'm taking a bit of a different approach then what others have been doing. Its pretty similar to how eyevan did his over on CT.
I took apart the headlights then removed the reflectors. From there I cut off the stock adjustment knobs and bored out the whole so I could mount my own bolt. Used nuts, locknuts and washers to hold the 2 main support bolts in place while jb welding the back to make it extra sturdy. From there I proceeded to make the mounting plate. Marked the holes to be drilled and cut some threaded rod to act as the main supports and means of adjustment. The threaded rod is held in place with nuts and washers. All mechanical mounting hardware was given a healthy dose of loctite to prevent it from undoing itself from vibrations. The plate was also spot jb welded to make it more secure.
Shot with Canon PowerShot SD630 at 2007-09-09
To hide everything some thin ABS plastic was cut to shape. I marked the center where the projector would protrude from and cut the hole as exact as I could get it. There is a small gap where you can see inside so that will be siliconed to seal it (black silicone will be used). The finished product should look like this
Shot with Canon PowerShot SD630 at 2007-11-23
Shot with Canon PowerShot SD630 at 2007-11-29
Will be posting up more updates as I go.
