First off I did the install myself...after reading every single thread and tips/tricks/dos/don'ts I can find between xr-underground/tacomaworld/customtacos at least three times.
I have every single tool needed to do the job correctly so there is no issue there.
Now the story...purchased the urd stage2 clutch combo (pplate/light flywheel/throwout bearing/arp bolts).
Initially only needed to replace the throwout bearing but everyone suggested "might as well upgrade the clutch since you have to drop the trans".
Did some research and started a thread here and the consensus was urd stage2 for my goals.
Get the package on a friday and had it installed by saturday night. Everything aligned fine, pplate pressed down in increments using star pattern to ensure even pressure, everything was handled with clean nylon gloves (one set of gloves for flywheel, one for clutch disc, etc.), and flywheel/pplate cleaned with brake cleaner many times over.
Everything back up and bolted correctly with no extra/missing bolts. Clutch pedal adjusted to about 2mm of free play.
Test drive resulted in first gear and reverse gear shudder. No problems getting into any gear, second through sixth have no grinds, chatter in gears 2 through 4 if I happen to be under 1500 rpms (second gear at 15mph for example)
I thought maybe it was the clutch breaking in so drove it lightly for the first 500 miles (stop and go and never got above 2700 rpm).
500 miles of break in and it didn't get any better. Saw a thread where it was suggested to adjust clutch pedal free play. Already at 2mm I got it to 0 and shudder still persists.
My stock flywheel, clutch disc and pplate were still in good condition so yesterday I re-installed it the exact same way I installed the stage2 combo. At first I was going to chalk it up to a botched install on my part but since I re-installed the stock components the same way I installed the stage2 I'm wondering if I really did botch the install. I'm also taking into consideration the fact that my stock components were already working to begin with so re-installing them simply reverted it back to the way it was (no shuddering, no chatter, etc.) and may not be a good indicator of a botched install on the stage2.
Here's what I found:
urd pplate
light steel flywheel
stage2 disc : the wear on the pplate side is similiar to the wear on the flywheel side
How do I check if the pplate and/or clutch disc are warped/bent?
Thanks for looking everyone.
urd pplate
