Drift day at Willow Springs
hottacoX
A .5 mm is standard "over bore" when rebuilding a block, it ensures the cylinder will be remachined into round instead of being oval... I did this to be on the safe side with my new pistons, went with a 94.5mm instead of the stock 94mm.
Last thing i wanted is to go through the build and not have the pistons seal the cylinder properly.
Now with our open deck it was really making me think hard about sleeving it since some get cylinder wobble already but at this point i can't afford the sleeves so we shall see how well it does!
picaCulo
Wow that really sucks man , hopefully you can get it up and running soon
sdxrunner619
Im 99% sure your not supposed to over bore our engines due to the cast iron sleeves not being thick enough...
Yes. LCE has actually over bored .020" more than factory. Even at the time when I first built my engine. They have done that on a large number of engines.
hottacoX
^^ yes twenty over is the common term for doing it, torspd was your original engine overbored?
Nope. Only the second built engine. From 3.701" to 3.708" to allow expansion room for the 3.704" pistons.
