E-Fan Mod
Discussion in 'N/A Mods & Tuning' started by X'ED, Nov 22, 2008.
  1. X'ED
    X'ED New Member
    Oct 9, 2007
    618
    Well ive been reading ketchups write-up on this http://www.xr-underground.com/vb3/showthread.php?t=18133 and was wondering would this void any warry's from toyota? and also what is a good fan, meaning, like what car, truck...ect is a good fit for the x.? one more thing, what are the upsides to doing this mod?
    thanks, and nice write-up ketchup.
  2. KETCHUP
    KETCHUP Active Member
    Nov 1, 2007
    11,665
    Don't know about warranty?? Ive done so much to my truck.....I would imagine that mine is gone. I would call Toyota. I'm sure someone will chime in on this one.
    You can select almost any dual fan. Mine was off a Nissan Sentra I believe. It really wasn't hard to do. The small advantage that you will see is less lag on the engine during a RPM cycle. It revs faster.
    The only thing I have done since the write up is install a kill switch (interrupter) so that I can shut the fan off when Im just sitting with the engine off. If you have any other questions, let me know.
  3. X'ED
    X'ED New Member
    Oct 9, 2007
    618
    thanks, the "kill" switch, you shouldnt need that if you have a adjst. thermostat or would you?
  4. KETCHUP
    Nov 1, 2007
    11,665
    I bought that kit you see in the write up, but the thermostat was bad. Never took it back. Just ended up wiring it on a accessory wire, so it comes on when the key is over. I need to just buy a kit, take the thermostat out and send the messed up on back....just haven't.
  5. X'ED
    X'ED New Member
    Oct 9, 2007
    618
    got it, thanks man
  6. Organic Mechanic
    Organic Mechanic New Member
    179
  7. X'ED
    X'ED New Member
    Oct 9, 2007
    618
    sweet, looks likt it will move some air.. cant wait to see the price tag on it... 200.. 275 maybe
    its nice thats its a "bolt" on to
  8. KETCHUP
    Nov 1, 2007
    11,665
    Very nice. My getto fan only cost me 40 bucks at a junk yard....:biggrin:
  9. X'ED
    X'ED New Member
    Oct 9, 2007
    618
    i think i might go getto too.... cause that dont come out till jan. 09 and theres no telling the cost of it
  10. T0LLPHR33
    T0LLPHR33 "Catwoman"
    Jun 17, 2008
    10,969
    i wanted a dual but i think i'll be getting this setup after the holidays...:top:
  11. quicky06
    quicky06 New Member
    May 20, 2007
    754
    sammit seeing that dan setup makes me hope i dont get the fans i asked for for christmans lol. ill just have to return them and get that.
  12. X'ED
    X'ED New Member
    Oct 9, 2007
    618
    yup thats why i think i going to copy ketchup's....or buy a dual flex-a-lite fan that will fit
  13. X_RUNNIN
    X_RUNNIN New Member
    Apr 21, 2008
    439
    hey ketchup...whats the specs on ur fans? if you know them like the total length, fan diameter, width, depth, and cfm
  14. My68ur8trd
    My68ur8trd Active Member
    4,672
    thats pretty sweet.
    i had bad luck with the perma-cool fan
    i like this bolt on fan
    Justin
  15. KETCHUP
    Nov 1, 2007
    11,665
    I would get them for you, but my truck is still in the paint shop.....:motz:
    Before I bought it, I just measured the radiator with the fan scroud off. Then used that measurement as a guide. I really think that an dual fan will work though, when you consider that our stock fan is single and still manages to keep the engine cool. I haven't had any cooling problems.
  16. X'ED
    X'ED New Member
    Oct 9, 2007
    618
  17. T0LLPHR33
    Jun 17, 2008
    10,969
    i don't think those would fit unless you made some custom mounts. but i think those would be BA...:top:
    these are the Dual EF that i wanted from Flex-A-Lite...:biggrin:
    NEW 27" Electric Fan (dual 13.5")
    Part #292, 295 & 298 - Puller Only
    This is our newest fan, designed to fit mid-size domestic cars, trucks and SUVs.
    These 27” electric fans are configured to maximize the radiator coverage on these vehicles while providing the largest air-moving capacity possible. Includes universal mounting brackets to position
    the fan without penetrating the radiator core.
    Features:
    • Powerful twin 13.5" fans in a compact package
    • One piece glass-reinforced nylon shroud with full contact rubber seal
    • Built in variable speed control module with adjustable thermostat, A/C relay and manual switch connection
    • Variable speed control operates the fan from 60% - 100%
    • Airflow flaps allow maximum ram air cooling while fan is not operating
    • Cooler A/C output
    OR...
    TECH SPECS
    # 225 (BLACK ONLY)
    BLADE DIAMETER​
    2 @ 12"​
    FAN DIMENSIONS​
    15 1/2" X 26 1/4" X 2 5/8" THICK​
    AMP DRAW​
    19.5​
    FAN R.P.M.@13.5VDC​
    2000​
    NUMBER OF BLADES​
    2 @ 10​
    FAN BLADE ANGLE​
    18 - 40​
    made for Toyota Supra...slim design that way if you want to get a Turbo Setup you have room for piping and Intercooler...:biggrin:
  18. KETCHUP
    Nov 1, 2007
    11,665
    One thing to keep in mind when doing this mod is the overflow reservoir for the radiator. The stock one is attached to the fan shroud. I couldn't get it to come out. I just bought a universal one and attached it on the left side of the engine compartment near the air box. Just FYI.
    Also, if you use a fan from a junk yard, you will likely have to make your own fan mounts....as I did. I used some sheet metal brackets that I purchased from Home Depot (in the lumber section).​
  19. My68ur8trd
    4,672
    are you not using the factory shroud anymore?
    Justin
  20. T0LLPHR33
    Jun 17, 2008
    10,969
    thanks for the information bro. I was also wondering how big of a remote overflor reservoir do you need for the radiator...and where and how much do they cost...:hmmmm2:
