FAQ: Complete X-Runner Specs
Discussion in 'FAQs' started by XrunnIT, Apr 28, 2008.
  1. XrunnIT
    XrunnIT Active Member
    Jul 29, 2007
    8,044
    Official specs for the Toyota X-Runner. :top:
    ENGINE
    4.0-liter DOHC EFI V6,
    24-valve aluminum block with aluminum alloy head with VVT-i
    236 hp @ 5,200 rpm
    266 lb-ft @ 3,800 rpm
    Bore & Stroke: 3.70 x 3.74
    Displacement: 3,956 cc
    Compression Ratio: 10.0:1
    Ignition System: DIS (Direct)
    Fuel System: EFI
    Recommended Fuel: 91-oct
    Emissions: LEV-II
    DRIVETRAIN
    6-speed manual overdrive (V6)
    Drive System Type: 4x2 front engine with rear-wheel drive
    RATIOS:
    * 1st 4.17
    * 2nd 2.19
    * 3rd 1.49
    * 4th 1.19
    * 5th 1.00
    * 6th 0.85
    * Reverse 3.61
    * Final Gear 3.153
    WHEELS AND TIRES
    18 x 8 Alloy
    Bridgestone Potenza RE050 255/45/ZR18
    Bolt pattern is 5x4.5", 5x114.3mm
    Lug nut size is 12mm x 1.50
    Offset is +30mm.
    Center Bore is 60mm
    Wheel weight is 31lbs - 32lbs
    Tire weight is 29lbs
    SUSPENSION
    Front: Coil spring independent double wishbone with gas-filled shock absorbers (4x2 – low mount)
    Rear: Leaf spring rigid suspension
    Front Stabilizer Bar Diameter (inches): 1.18
    Rear Stabilizer Bar Diameter (inches): 0.98
    BRAKES
    Power-assisted four-wheel Anti-lock Brake System (ABS) with Brake Assist (BA) and Electronic Braking Distribution (EBD)
    Front: Ventilated Disc
    Front Diameter: 10.83-inches
    Front Swept Area: 56.75 square inches
    Rear: Leading-Trailing Drum
    Rear Diameter: 10-inches
    Rear Swept Area: 61.82 square inches
    Parking Brake: Stick Type
    STEERING
    Ratio: 17.4
    Turns (lock to lock): 3.43 turns
    Turning Circle (ft.): 42.0
    CAPACITY
    Fuel Tank: 21 gallons
    Cooling System (quarts): 10.3
    Engine Oil (quarts): 4.4 w/o filter change, 4.8 w/filter change
    EXTERIOR DIMENSIONS
    Overall Height: 65.2
    Overall Width: 74.0
    Overall Length: 208.1
    Wheelbase: 127.2
    Inside Bed Length: 73.5
    Inside Bed Depth: 18.0
    Inside Bed Width-
    At Tailgate: 52.9
    At C-Channel: 56.7
    Between Wheel wells: 41.5
    Front Track/Rear Track: 62.2/62.2
    Running Ground Clearance: 7.5
    Coefficient of Drag: 0.368
    INTERIOR DIMENSIONS
    Headroom (front/rear): 39.9/35.2
    Legroom (front/rear): 41.7/28.2
    Shoulder Room (front/rear): 57.7/57.7
    Hip Room (front/rear): 53.6/53.6
    Maximum Seating Capacity: 4
    EPA ESTIMATED FUEL ECONOMY (mpg)
    6-speed manual (V6): 15/19
    VEHICLE MASS (lbs)
    Curb Weight (man): 3,690
    GVWR: 4600
    Payload (man): 910
    TOWING (lbs)
    Towing Capacity: 3,500
    Tongue Weight: 350
    Gross Combined Weight Rating (GCWR): 7500
    ANGLE OF APPROACH/DEPARTURE (degrees)
    Approach: 19
    Departure: 19
    Break over angle: 15
    PERFORMANCE (As tested by 3rd parties)
    *Acceleration 0-60: 6.9 sec
    *Quarter-mile elapsed time: 14.92 @ 93.10
    600-ft slalom: 63.67 mph
    Lateral Grip (200ft skidpad): 0.97G
    *These times are listed as corrected times by Motor Trend, and not the actual times. Actual stock 1/4 times vary, most run low-mid 15's trapping 89-91mph.
    #1 XrunnIT, Apr 28, 2008
  2. rx-runner
    rx-runner New Member
    is the towing capacity regarding the trailer hitch or putting a ball joint on the rear bumper
  3. XrunnIT
    Jul 29, 2007
    8,044
    From the bumper, in the specs they didn't have any specs for a trailer hitch. :thumpdown:
  4. RJDoute
    RJDoute "My Salami Nipples Ooze Milk"
    Mar 4, 2008
    3,360
    Sticky this is useful stuff. :top:
    EDIT:
    You're a moderator. Of course it's stickied. I'm going to go bury my head now. :top:
  5. rx-runner
    well ill be, those are still great numbers
  6. Grumpy
    Grumpy New Member
    Jun 16, 2007
    5,051
    Awesome, lots of useful reference material.
    Isn't our MPG 17/21?:dontknow:
  7. TitanRattler813
    Feb 28, 2007
    7,656
    33
    source of info?
    I usually either use MSN Autos or if I don't have the net, I dig through the manual.
  8. XrunnIT
    Jul 29, 2007
    8,044
    This is from Toyota themselves, as the Official specs. I have the PDF doc that has the info for all the trims, so i parsed out just the XR stuff. :top:
  9. TitanRattler813
    Feb 28, 2007
    7,656
    33
    cool :top: ... now my 18 mpg doesn't seem like I'm doing so bad. I just moved up to a higher percentile :laugh:
    Like Grumpy asked, I always thought it was 17/21, but I'm more like 16/18
  10. XrunnIT
    Jul 29, 2007
    8,044
    I usually got between 15/18 with city/highway mix before my mods, then it went up to about 17/20. Then with the blower only one tank at it was about 16 (and that's with my foot in it all the time :biggrin:)
  11. Grumpy
    Grumpy New Member
    Jun 16, 2007
    5,051
    I regularly get high 19s (80% hwy), with the last tank came in at 20.44mpg. That's only because I'm in grandma mode breaking in my short block.
  12. LOW AND BLOWN
    LOW AND BLOWN Active Member
    Sep 25, 2007
    1,016
    I get 100 miles or a little more per hash mark on the fuel gage,which is about 19-20 mpg.
  13. XrunnIT
    Jul 29, 2007
    8,044
    We've already got a thread discussing gas mileage so lets keep this thread on topic with spec related conversation, and MPG in this thread --> Gas mileage
  14. mad hatter
    mad hatter New Member
    May 31, 2008
    31
    what about 0-60 and skid pad?
    I've read that the 0-60 is 5.7 or something close and the skidpad is 1.9 Gs. Confirmation?
  15. 08x
    08x New Member
    Mar 23, 2008
    1,710
    for sum reason some of the info doesnt seem rite as in the oil capactiy is not rite at all i work at a toyota dealership and 4.4 quarts ona 4.0 v6 is low
  16. blazinx
    blazinx Active Member
    Mar 3, 2007
    1,989
    so i guess im doing it wrong by puting regular pump gas instead of mid grade?
  17. Spyder327
    Spyder327 New Member
    7,098
    91 is recommended but not required.
  18. Stevenredx
    Stevenredx New Member
    Skidpad is close to 1.0 g.... something like .96 to be exact, i believe
  19. XrunnIT
    Jul 29, 2007
    8,044
    .97G as recorded by Toyota and TRD.
    Updated first post with performance section. :top:
  20. Tapp
    Tapp New Member
    May 2, 2007
    4,383
    so what do you think 0-60 is with the TRD blower??
