T0LLPHR33
"Catwoman"
- Jun 17, 2008
- 10,969
I had no idea after installing the APR X-1 Controller that it uses the check engine light as a shift light...:biggrin: very cool indeed...:top:
I wonder if you changed the LED cluster for the check engine light to do a multi color: green, yellow, then red if you could set individual timings so that once you start hitting 6K instead of flashing it will go green, then as you get closer to redlining it will change to yellow, then once you hit the rev-limiter it flashes to red and holds...:hmmmm2: that's going to be something I"m going to have to look into...:biggrin:
I already have a shift light. The APR X-1 uses the check engine light as a shift light. My redline is set at 6200 and the check engine light will start flashing at 6000. I just thought with one gauge to show it all it would look good to have a single pod.
