brs
- Oct 30, 2015
- 17
- 1
I'm hoping someone out there can help diagnose the following problem...
Several years ago I installed the front Rotara disks and they worked fine, better than stock for sure.
Last week my local shop installed the "TundraRacing Pro Series Rear Disc Conversion kit". The installer was familiar with the SSBC calipers and has installed several but not on tacomas. After the install the brakes felt spongy like air in the line. After spending hours flushing the lines then eventually doing a power flush they managed to find some small bubbles but the situation was only slightly improved. We are fairly sure that no air exists in those lines.
Now, when the engine is off the brakes pump up and give a firm high pedal. Once the engine is started then they feel spongy. After about a half inch of travel I feel light braking begin but it does not continue to get stronger as fast as you would expect and the pedal goes down quite far to start getting good braking. To activate the ABS even on wet roads takes quite an effort. Nothing near as good braking performance that I had before removing the drums.
So, if it's not air what could it be?
And, has anyone else installed these rear brakes?
I'm stumped, the shop is stumped, and TundraRacing is stumped too.
