Rear Brake Conversion
Should I do a rear brake conversion?
  • Total voters
    134
sdxrunner619
I've been thinking about this. My last truck had rear drums and I replaced them with a kit from SSBC. In the instructions with that kit, it said to remove the residual pressure spring in the master cylinder. Has anybody with a rear disk conversion done or tired that?
Rick
Not that im aware of. Never even removed my Master cylinder. I installed a a adjustable proportioning valve, and that solved my brake bias issue. Keep in mind, i have the 6-piston 355 rotora with the Tundra racing is350 rear disk conversion.
I strongly DO-NOT recommend it do the terrible instructions, brake bias issues and cost. If you really want to increase your stopping power, pick up a used TRD BBK/ Rotora BBK.
I recommend the TRD BBK (stoptech), do to better options for aftermarket pads. Rotora has no aftermarket pad support, shitty hardware, and some bad QC issues on many products. :thumbdown:
darthyota
Kevin have you thought about fitting a fj master cylinder?
sdxrunner619
Newp. My proportioning valve works fine. :rolleyez:
Dont those use the God-fordaken Hydro-boost/integral master cylinder power assist....:hmmmm2:
darthyota
I'm not sure but I would assume that they are setup to properly proportion rear discs and should bolt into a taco
livinginsa
I did the Rotoras. The fronts were real easy to do but the back ones were hard to do. For one thing, there weren't any real instructions. Then there is a lot more to do on the rear ones. It took me about a couple of hours to do the front ones, only because I had never done them before, and it took me a few days to do the back ones. Next time I could get it all done in the same day. I like the looks, most of all.
I used to hate the way my X stopped but now it stops really quick. I think the brakes would heat up too much to stop all of that weight, and it wouldn't stop very quickly. Now, the brakes are not a weak link in my system.
sdxrunner619
I could never justify spending several grand just for looks...but to each their own. If your X is out on road courses tearing it up, hot-lapping it...then fine, maybe a BBK out back will help...Even so, we have most of weight up front, and weight transfers forward under braking....simply put, we dont need massive brakes out back. I can only imagine how much of a over kill a multi-piston set up would be on our trucks rear end...:laugh:
Hell, one member has Carbotech coated brakes shoes for his drums...:top:
Coming from someone who actually REALLY pushes his XR, i regret spending the $1000 on the rear disk conversion...It was really not worth it.
autobodyX
I'am the one with the carbotech conversion on my 06 and I bought a 09 with the stop tech front and the is 350 rear conversion tundra racing sells. I purchased the 09 truck from azburnin. I think the brake package works good and that it is worth the money. The e- brake has to be pulled a litter harder but works good. I look forward to taking it to the track soon!
I hear that Carbotech has replacement pads for the Rotora brakes.
sdxrunner619
...you have my attention....BTW, do you still have your old pads from your bbk? There is a company out here who will.coat the pads in what ever compound you want/need. But I'll need a spare set...:smile:
X-roller
Damn... I remember when I started this thread... I ended up going TRD BBK for now.
hottacoX
If I am not mistaken at the time x-roller went with the trd setup due to the price he was able to get them for. I have the rotora kit and it works really well, but as posted earlier if you want more pad options go with the stoptech:top:
I believe that you can get CarboTech pads for the Rotora's as well. :top:
I have the Rotora brakes, front and back, from TundraRacing.com. They suck. They work great but they are loud. They have been loudn since they were brand new. They squeel like a pig but much louder. I replaced the brand new pads with another set of brand new pads, and they were the same, loud, very loud.l I would go with another supplier and another company.
TRD-X
Tundra Racing offers a front and rear StopTech kit look at the link.. :top:
Link >>>> http://tundraracing.com/330xrunnerrotora.htm
sonic555u
yes do it
Go to tundra racing they sell the stoptech kit that makes it for trd, they have thre front and rear kit and there balanced I only have the front and i love it i eventually want to get the rear kit but dont have the funds currently.
Clifford
because race truck
Everyone who has it and the people who sell it.
