Recessed grill mod, removed front plastic piece, recessed lower grill mod.
Discussion in 'Exterior Modifications' started by Organic Mechanic, Aug 3, 2008.
  1. Stevenredx
    Stevenredx New Member
    ^^ correct... your mainly seeing the condenser. Look at when you get a chance and you will see that the radiator is behind it. I think when i did mine I picked up some high heat engine paint or something but it really doesn't matter. Just a couple of light coats and your good :top:
  2. 5000XD
    5000XD New Member
    3,774
    Its from the a/c. I would go for high heat. Another thing is that they sell special paint for radiators, might be that those pass on heat easier.
  3. Hitman
    Hitman Active Member
    2,765
    do you know of a website that sells these special paints.
    I will try googleing it :top:
  4. BSPX
    BSPX Member
    May 14, 2007
    583
    so can we get a pic of how you attached the mesh to the grill?
  5. 5000XD
    5000XD New Member
    3,774
    Well more then a year back, www.eastwoodco.com had radiator paint.
    and they still seem to sell it:Click :top:
  6. jaxchrisfla
    jaxchrisfla Active Member
    May 29, 2007
    7,560
    yup that is the a/c condenser. in most vehicles these days they are always infront of the radiator.
  7. Hitman
    2,765
    Which would match the BSP the Satin or the Gloss I can't tell the difference:dontknow:
    Yeah im interested in how this is done did you use sip ties or something?
  8. Tapp
    Tapp New Member
    May 2, 2007
    4,383
    i used zip ties..i think a total of eight...that sucker isnt goin anywhere!
  9. Hitman
    2,765
    where did you tie them too :dontknow:
  10. Organic Mechanic
    Organic Mechanic New Member
    179
    complete
    Got a few small things I need to touch up, but it is generally done. I also added a rubber body-kit grommet to center part of the front skirt, to fill in for a piece I removed.
    Something is still missing... and its the headlights, which I should get in a week or two. They will tie everything together, and it will look perfect.
    I am also thinking of adding a red TOYOTA badge in the bottom right corner.
    The main grill and lower bumper opening are secured with zip ties. The upper grill had 3 factory spots that worked. I added a few 45deg small door hinge brackets with some mounting tape, and zip tied to them.
    The corner triangles are glued in with a two part, collision repair structural glue that I got from one of the body-shop guys at Heintz.
    #70 Organic Mechanic, Aug 8, 2008
  11. blackx-runner
    blackx-runner "White Flash"
    7,581
    13
    That looks sick man :top:
    I would do that, but I don't think that my URD air intake will fit behind the grill if its recessed :hmmmm2:
  12. jmoore120
    jmoore120 Active Member
    Dec 13, 2007
    1,457
    Love the way that looks. Good Job :top:
  13. rich017
    rich017 Active Member
    Aug 23, 2007
    6,328
    I think it might. The stock grill is thick and whenyou do the recessed grill it's just as far back as the stock grill is thick
  14. jaxchrisfla
    May 29, 2007
    7,560
    It fits, ive got it on mine. but isnt there a heat exchanger up there?
  15. blackx-runner
    7,581
    13
    the heat exchanger is behind the lower grill for the URD charger :top:
  16. jaxchrisfla
    May 29, 2007
    7,560
    ah, then it should work fine for you. its a little tight in there, but it fits. be ready to protect the maf sensor though.
  17. blackx-runner
    7,581
    13
    thats what I was afraid of. My truck already has issues in heavy rains. :thumpdown:
  18. beastbluetaco
    beastbluetaco New Member
    Feb 8, 2008
    230
    Looks awesome!!
  19. gixxerman11
    gixxerman11 Guest
    it does look good u can put some plastic gutter screen behind it so u dont have to paint it
  20. Organic Mechanic
    179
    I'm going to move the horn and see how it looks, but Ill probably end up painting it.
    Summit racing has some dupli-color Radiator paint, Ill probably order up some of that.
    I used their brake caliper paint kit on my Rx-7 and it worked great.
