Here is a fix that is cheap and very easy to do for the XR owners that are over 3 years 36K miles (out of warranty) and side panels are not cracked yet, the way I understand the TSB is that only the X's that are cracked and under 3/ 36 are covered, and that if is not cracked then basically they just inspect and do not install any kind of reinforcement so eventually on down the road and out of warranty it may possibly over time crack, this fix should keep the rear fender panels from cracking by stopping the flex of the fender which is due to very rough roads over time and I didn't say this but wheel hopping doesn't help either, Hope this helps some of our XR owners, You can find a strip of aluminum at Home Depot, Lowes, etc. for just a few dollars.
