sytfu510's Supercharged Long Travel Build
Discussion in 'Member Builds' started by sytfu510, Oct 15, 2015.
  1. sytfu510
    sytfu510 New Member
    Mar 17, 2014
    31
    Although I don't have an X-Runner I do frequent the forums as there's tons of info regarding the boosted Tacoma's
    But since I'm here, thought I'd post my build up.
    Instagram: sytfu510
    Projects in progress:
    Solid Motor Mounts
    DMZ mount gussets
    Secondary Shock Hoops
    King 8" Triple Bypasses
    Deaver Leaf Pack that can handle the weight
    Latest Pictures:
    NEWEST MODS:
    Dirt Designs 4wd Long Travel Race Kit
    King 8" Coilovers w/ 700# Spring
    First Picture with the truck as I got it from the dealer:
    ARMOR:
    -B.A.M.F. Rear Diff Skid
    -B.A.M.F. Sliders w/Kick Out
    -ATO Front IFS Skid
    -BruteForce HC Tube Bumper w/Swing Down Tire Carrier
    -Budbuilt Gas Tank Strap
    -Pelfreybuilt Aluminum Gas Tank Skid
    -Pelfreybuilt Hybrid Front Bumper
    SUSPENSION:
    FRONT:
    -King Racing 8 x 2.5 Coilovers w/ Remote Res
    -Dirt Designs 4wd Race Long Travel Kit
    -Wheelers Super Bump-stops
    -Total Chaos Shocks Tower Gussets
    -Total Chaos Alignment Tab Gussests
    REAR:
    -DMZ SUA Long Travel Kit
    -Infamous Metal Works Bed Cage
    -Boxed Frame w/New Cross-members
    -Deaver LT Springs + AAL
    -King Racing 16" 2.5 Triple Bypass Shocks w/ Remote Resi's
    -Bay Area Metal Fab ( B.A.M.F. ) Outer Frame Gussets
    -Fox 2.0 Air Bumps 2" Travel
    -Poly-Performance Air Bump Mounts
    -18" Limit Straps
    RECOVERY:
    -SmittyBilt XRC-8 8000k COMP Winch(Synthetic Rope & Aluminum Fairlead)
    -SmittyBilt Recovery Kit w/ Snatch Block, Tree Saver, Chain
    -SmittyBilt Recovery Strap 2 x 20ft
    -SmittyBilt Element Ramps
    -Hi-Lift Xtreme 48" Jack
    -Hi-Lift Base
    -SmittyBilt Snatch Strap
    -Smittybilt Recovery Strap
    -ARB Winch Extension Strap
    -Factor 55 FlatLink
    DRIVE-TRAIN:
    -ARB Rear Air Locker
    -ARB High Vol Air Compressor w/Air Line Kit
    -Rear Diff Breather Extension/Relocation Mod
    -ARB Front Locker
    -G2 4.56 Front & Rear Gears
    -JD Rear Diff Crush Bushing Eliminator Kit
    -B&M Trans Cooler
    EXTERIOR:
    -Cut Rear Fender
    -GrillCraft Grille
    -Glassworks 4" Wide 3" rise Fenders
    LIGHTING:
    -OKLedLightbars.com 40" Double Row LED Bar
    -OKLedLightbars.com 20" Double Row LED Bar
    -OKLedLightbars.com 3" LED Spot Lights x 2
    -OkLedLightbars.com Rock Lights x 6
    -OkLedLightbars.com Rock Lights on bed rack x 4
    -B.A.M.F. Behind the Grill Light Mount
    -Depo OEM BHM leadlights
    -CBI off road Ditch Light Brackets
    WHEELS/TIRES:
    -Hankook DynaPro M/T 35x12.5x17 ( x 5 )
    -SCS SR8 Matte/Gloss Black [ 17 x 8 / 0 Offset / 4.5 BS ] ( x 5 )
    -SpiderTrax 1.25 Wheel Spacers Rear
    INTERIOR:
    -WeatherTech Floor Liners F & R
    -Illuminated 4 x 4 switch
    -Salex Glove Box & Console Organizers
    -Tech Deck Mount
    -Ram Phone Mount
    -Ram Tablet Mount
    -Blue Ridge Overland Gear Seat Molle Panel
    -Blue Ridge Overland Gear Visor Molle Panel
    ELECTRONICS:
    -Yaesu Dual Band Ham Radio
    -Cobra 40 Channel CB Radio
    -Firestik 4ft Fiberglass Whip Ant.
    -Scangauge Ultra II
    -Blue Sea 12 Slot Fuse Block
    -HiFonics Components F & R
    -DVRyourcar.com Car DVR system
    -Otattw switches & covers
    ENGINE:
    -TRD Supercharger
    -TRD Intake System w/ AFe Filter
    -Doug Thorley Shorty Headers
    -MBRP Catback Turn Down Exhaust
    BRAKES:
    -EBC Extra Duty Pads
    -EBC Slotted/Dimpled Rotors
    -Goodrich Stainless Brake Lines Front
    -All Pro Extended Brake Lines Rear
    MISC:
    -EZ Lift TailGate Shock
    -Redline Hood Shocks
    -B.A.M.F. Fuse Block Mount
    -2 RotoPax 2 Gal Gas Carriers
    -2 RotoPax 2 Gal Water Carrier w/Bed Mount
    -20lb C02 air system
    -Wheelers c02 155 psi regulator
    -Wheelers 20# Mount
    -Wheelers 20' Coiled Hose
    -VIAIR 0-200psi Regulator
    STORAGE:
    -B.A.M.F. Custom Bed Rack ( w/swing out arm for shower )
    -PrinSu Aluminum Low Profile Roof Rack
    -Rubber Maid Action Packers
    -Bed Slide 1000CL
    OFF ROAD GEAR:
    -ARB 6.5ft Retractable Awning
    -ARB Mosquito Netting for Awning
    -TruckFridge.com 40L Fridge/Freezer ( Indel B ) [ page 21 ]
    -ARB Fridge Tie Downs [ page 21 ]
    -Ironman 4x4 Fridge Insulated Cover [ page 21 ]
    -Custom Built Fridge Slide [ page 21 ]
    -Tepui Roof Top Tent
  2. sytfu510
    sytfu510 New Member
    Mar 17, 2014
    31
  3. Redlantern
    Redlantern Member
    Jan 28, 2013
    520
    Aloha. Welcome to xru! Loving the start of your build thread.
    Did your truck come with an elocker before you put arb air locker for the rear? If you did, im curious as to how you took care of elocker removal and if it interferes with the abs system.
  4. blackx-runner
    blackx-runner "White Flash"
    7,581
    13
    That's a hell of a build. Looks like a fun truck.
  5. sytfu510
    sytfu510 New Member
    Mar 17, 2014
    31
    Thanks! My truck was a TRD Sport, so I had the LSD. So Swapping to the ARB wasn't a big issue.
    Thanks! Does have its moments!
  6. BSP06XRU
    BSP06XRU Old Member
    May 14, 2007
    12,940
    55
    Nice build! :top:
  7. hrspwr236
    hrspwr236 Active Member
    Jul 2, 2007
    8,886
    Truck has soooooo much want!
  8. Torspd
    47
    :adore: Now THAT is a build!
  9. Torspd
    47
    I'm planning on the solid engine mounts as well. Looks like a very worthy upgrade for owners of the Spec-U headers, who do serious dirt hooning. To much flex in the OEM mounts.
  10. sytfu510
    sytfu510 New Member
    Mar 17, 2014
    31
    thanks!
    Yeah, I've got video from under my truck and the whole engine rocks. Not good for power transfer, or any lines that may rub. Not going to be a fun install but will be well worth it I believe.
  11. lamia2super
    lamia2super Member
    Jan 27, 2013
    647
    awesome! i was just telling some friends that my next build should be a long travel suspension on boost
  12. sytfu510
    sytfu510 New Member
    Mar 17, 2014
    31
    yeah man you'll love it. Lots of fun off road. and you still have your X-runner to kill the streets. :top:
  13. Torspd
    47
    Yeah, those headers are going to extend the time just a tad..;)
