xrunnerdude67
- Mar 23, 2007
- 115
It equals out to be $128.52 USD
SignUp Now!im spoiled with just my remote start
how did you teach urself not to park in gear??? That is my biggest problem with getting remote start.
Yeah that is only for vehicles with the keyless smart key systems, if you look at all the models they list they are not sold in the U.S. the only ones sold here are certain models of Avalons, Camrys, Hybrid Camry, Hybrid Highlanders and Prius, they do list a Rav4 but I have not seens one of those in the U.S. either with smart key.May run into issues with this as the description plainly states it is *Only for vehicle equipped with smart entry system and start system :dontknow: Sounds like it would have to be hard wired to the ECU, if it is capable of handling the command. Where are you Master Tech ???
i wouldnt mind one even if you had to use the key. just to not have to push the clutch all the way to the floor is what i want.
if u don't want to push in the clutch then try moving the sensor from the clutch i bet its like the brake light switch:top:
That's smart key, depending on what year, there should be a smart key button under the steering wheel on the lower dash cover that you can push and it will enable you to use the start push button with the key in your pocket (not in the slot)when I was driing the prius it had the push start. But it had a rectangle key you had to insert first before it would start.
