Un locking and locking door's with key fob
Nashman
I was wondering if could make my horn toot every time I locked my doors is this possible ???
shane881510
I want mine to beep also when I lock and unlock my doors .
MiamiChillin
Yeaaa I want mine to beep when I lock her. Im paranoid of leaving my truck unlocked. The beep is so reassuring lol.
Coupe
I believe that trucks that were sold in the Gulf coast area had an alarm put on them. Part of this alarm has a red led/button to the left of the steering column. I can not remember if the light is on or off that makes the horn chirp.
I will see if I can find out.
In this pic you can see the red light/button, just right of the mirror controls.
Tom2769
Coupe, I'm loving those perforated leather seats - custom I assume? And what about that steering wheel cover? Please tell me that's not custom & tell me what brand it is...
MplsX
I have the VIP alarm on mine. I had to program it so the horn would NOT honk. Didn't want to disturb the neighbors when I leave for work very early in the morning. I can see the marker lights flash so I know that the doors are locked and the alarm is set. I never use the key in the door since it's blocked off.
Coupe
Steering wheel cover is from WheekSkins. You can get just about anything you want.
http://wheelskins.com/
I stitched it myself.
The seat covers are from Roadwire (a competitor to Katskins)
They have held up wheel. I had them professionally installed.
http://roadwire.com/
Nashman
So this mean to make it honk factory i have to buy more stuff from the stealer ship
Naaaa I don't feel like taking 2 liter sized shits
all just eat alot of pork and beans instead and make my own toots
Coupe
I robbed this from TW. Try this.
(a) Open the driver side door and insert the key into the ignition cylinder.
(b) Remove the key from the ignition cylinder and, within 5 seconds, reinsert the key and turn the ignition switch to ON.
(c) After 10 seconds, the system enters answer-back buzzer switching mode.
(d) Within 10 seconds after answer-back buzzer switching mode is started, if a transmitter button (the same button) is pressed twice, the answer-back buzzer setting changes (off to on, or on to off) to activate or disable answer-back by buzzer.
HINT: The driver side door is closed.
BSP06XRU
Old Member
I thought that was only if you had the VIP alarm.
Can't do anything to make it "beep" if you have the standard keyless door entry.
30Birdy
What is a VIP alarm? Was it a factory or dealer option?
