One more of the speculative post from a non URD TCAI owner!!!! LOL
You really should for the fun of it open your hood scoop. and watch how much more dirty you engine bay gets. I bet your biggest gain will be the dirt accumulation!
LOL
buy the TRD because the URD TCAI doesn't sound like it's for you
I guess I needed to add, that you need to hook up an intake tube to it.
Otherwise, yes it will just make your engine dirtier.
But I thought it would go without saying since we were talking about intakes.
Without running tubing to the hoodscoop, you might as well just take your hood off. It would have the same effect as just opening up the hood.
But your right, the URD intake isn't for me. I want a true ram air intake.:rockon:
the hood scoop won't work the way a real hood scoop would. It's not high enough off of the hood so it has a negitive preasure ... although some air would go in there... Dirt accumulation would be much worse.. trust me i had a ram air hood on my dakota with the opening alowing air in the engine compartment... it really got the engine dirty.
Huh? Negative pressure? You mean it would force air out? :bird: Oh wait, I forgot that would be positive pressure. Negative pressure is a vacum, which means it sucks air in.
Which explains why you had dirt on your engine.
Ok, if you had a true ram air hood on your Dodge, it would be connected to something to shove that air through your intake, and filter. Thereby negating your problem of a dirty engine.
True ram air intakes shove air into the intake and nowhere else. Otherwise you don't see all the benifet of having it because too much air will just flow past your intake.
The fact that more dirt gets into your engine bay only proves that if hooked up to an intake it would force air into your intake.
That is why all intakes have filters on them. To prevent dirt from getting into your engine.
