Going to do a dyno this saturday,which do you prefer to get the best results. 3rd or 4th?
JPAYNE722 Active Member Joined Oct 26, 2011 Messages 1,194 Reaction score 2 Apr 13, 2016 #1 Going to do a dyno this saturday,which do you prefer to get the best results. 3rd or 4th?
Gadget Well-Known Member Joined Jan 13, 2007 Messages 10,932 Reaction score 173 Apr 13, 2016 #2 I think on the stock trans 4th works best. Should be able to run out the RPM without hitting the rev limiter. What type of dyno are you going to run on?
JPAYNE722 Active Member Joined Oct 26, 2011 Messages 1,194 Reaction score 2 Apr 13, 2016 #3 Mustang dyno 1750 SE
Gadget Well-Known Member Joined Jan 13, 2007 Messages 10,932 Reaction score 173 Apr 13, 2016 #4 Unless you are going to tune a stand alone EMS, do not bother with a Mustang. If you are looking for a number to compare to other trucks, find a DynoJet dyno. G
30Birdy Member Joined May 3, 2015 Messages 281 Reaction score 23 Apr 14, 2016 #5 I always thought Dyno pulls should be done in the gear that places a 1:1 ratio between engine and transmission for the most accurate results and consistency. That is 5th is our trucks and that would be a crazy long pull.
JPAYNE722 Active Member Joined Oct 26, 2011 Messages 1,194 Reaction score 2 Apr 14, 2016 #6 Thats what i keep hearing is 5th but 5th is just crazy long lol
S STONER-X Active Member Joined May 15, 2008 Messages 3,372 Reaction score 1 Apr 14, 2016 #7 5th will hit the speed limiter.. 4th is your best bet
Gadget Well-Known Member Joined Jan 13, 2007 Messages 10,932 Reaction score 173 Apr 14, 2016 #8 I have done both 4th and 5th on the XR and there is no difference on a DynoJet. 4th is not exceed the speed limiter so it is the best gear. On the autos I use 3rd. G
XMPLRY808 Active Member Joined Dec 5, 2014 Messages 405 Reaction score 76 Apr 17, 2016 #9 With auto my friend redlantern had better results with 4th
Gadget Well-Known Member Joined Jan 13, 2007 Messages 10,932 Reaction score 173 Apr 17, 2016 #10 You canot get the full RPM sweep in 4ht on an auto. The speed limiter will stop the run to early.
XMPLRY808 Active Member Joined Dec 5, 2014 Messages 405 Reaction score 76 Apr 17, 2016 #11 My friend has uconn so if speed governor isn't a problem 4th gear will net you better results
1 12X-Runner New Member Joined Feb 13, 2016 Messages 6 Reaction score 0 Apr 23, 2016 #12 Neither one. It should be done in 5th gear, which is the 1:1 ratio gear. Any other gear will produce inaccurate results.
