rich017 said:
Yeah, I am sure they can find out anything they want to with their scan tool. You would have to wipe the PCM to remove everything
No we can't. You pull the battery for a few minutes the ECM starts fresh. The new laptop scan tools are legit but we can't see every little thing the car has ever done. It is constantly recording and deleting info but not very much. If your car sets a check engine light we can see what was happening 3 seconds before it set the code, 3 seconds after and everything in between. That's it. But in that time frame we can see everything and I mean everything.
Correction!
Unless it's a hard code then the only way to get rid of it is for the computer to run it's checks and see that everything is ok.
New tundras were setting some hard codes for vvti problems and technical told us it was from machining debris that weren't cleaned out well enough and it was clogging oil passages....
