Sensor Placement
A weld-in M18 X 1.5 boss is supplied for sensor installation. Mount the O2 sensor in the
exhaust system at least 18 inches downstream from the exhaust port. If you anticipate high
EGT’s (over 800C), run a turbocharger, run at high RPM for extended periods of time or plan on
running leaded race fuel then you must mount the sensor at least 36 inches or more downstream
of the exhaust port as all of these can cause the sensor to overheat. On turbocharged engines the
UEGO sensor must be installed after the turbo charger, if not, the pressure differential will
greatly effect the accuracy of the unit. In applications with a catalytic converter, the UEGO
sensor must be mounted BEFORE the converter. In applications with an auxiliary air pump, the
UEGO sensor must be mounted BEFORE the pump input to the exhaust stream. Installation
angle should be inclined at least 10° towards horizontal (electrical connection upwards, see
diagram) which prevents the collection of liquids between sensor housing and sensor element
during the cold start phase.
