LateOnTheBrakes
- Aug 2, 2009
- 310
- 1
I finally got to the point where the rubber bushing in my TRD SS got to have way too much play in it so it was time to tighten it up. I saw the options out there like Coupe's shifter mod and the guys that go the route of fully welding their shifter. I wanted the solid feel of the welded shifter with hopefully some reduced vibration. I started out by cutting the shifter and removing the rubber bushing. Coupe has an excellent write up that explains how to do this that:
http://www.xr-underground.com/vb3/showthread.php?t=31063&highlight=coupe+shifter
This left me with the lower portion of the picture looking like picture 1
Then I used the lathe at my work and turned down a piece of 416 stainless steel to fill in the inner tube portion of the top of the shifter and bored a hole through the center that was slightly larger than the lower shaft as seen in picture 2.
I then filled the top of the shifter with an industrial polyurethane adhesive. I am hoping that the extra mass from the steel round bar and the urethane will damp some of the vibration folks with the fully welded shifters have been seeing. The assembly fit together as seen in the pictures 3 & 4.
I then TIG welded the steel round bar to the top and bottom of the shifter as seen in the pictures 5 & 6.
I then spray painted over the welds with high temperature black paint and installed the shifter this afternoon. I have only driven it around the neighborhood up to third gear and the solid feel of the shifter without a rubber bushing is amazing. I did notice a little bit of gear noise in first and second gear and with my hand on the shifter, but it got better as I picked up speed. The vibration/noise is not bad in my opinion but I have not seen others' setups to see how they compare. I will drive it around for a few days and report back when I have been able to put it through its paces and do some highway driving.
