Write-Up: Spark Plug Change
Discussion in 'How-To' started by Stevenredx, Jun 15, 2009.
  1. Stevenredx
    Stevenredx New Member
    A really good write up that was done on TW. He removed a couple of hoses and things on the drivers side and I'm sure that makes it easier but it is possible with out doing any of that.
    CLICK HERE: Spark Plug Change How-To
  2. LateOnTheBrakes
    Aug 2, 2009
    310
    I would caution anyone from using anti-seize on the spark plugs AND torquing it to 15 ft*lbs as this write up suggests. I agree that the Toyota service manual specifies 15 ft*lbs, but if that is intended to be a dry-thread torque (no lubricant/anti-seize) by doing both you will be over torquing the plugs. I hope the engineers at Toyota over designed the thread engagement so they won't strip out if the threads are lubed. But I don't know anyone that wants to finds out the hard way.
  3. Scarface
    Scarface Active Member
    Aug 30, 2010
    1,746
    I just did this for my 30k & and it was a pita
  4. Generation-X
    Generation-X New Member
    Jan 10, 2009
    1,240
    You only have to remove the top bolt on the bracket and loosen the bottom to get it swung out the way. Otherwise thats on the money
  5. LateOnTheBrakes
    Aug 2, 2009
    310
    I hope not, I just bought plugs this morning. I do have the TRD intake though so the passenger side should be considerably easier.
  6. I<3JDM
    I<3JDM Member
    Sep 8, 2008
    475
    Thanks for sharing the write up. I will do this soon, I just hit 30,000.
  7. butters607
    butters607 Active Member
    Oct 3, 2009
    3,826
    You don't need to loosen anything or take off anything yes its easier but if youu use a long extension or two you don't need to just put in the ikh 24's yesterday used two 6 inch extensions for the one closest to the firewall on the drivers side you just have to sneak them through behind the heater core hoses to tighten I do not use anti seize ever and I tighten them just a little bit if you really pay close attention while your tightening them you can actually feel the washer start to almost squash down take it it for what its worth but that's how I do it and.I have never had no issues
  8. pinktaco
    pinktaco New Member
    Jul 4, 2010
    551
    when do you guys change your plugs? at how many miles?
  9. COMEGETSOME
    COMEGETSOME New Member
    Jul 2, 2008
    408
    Great info thanks for the wright up. Any.pics?
  10. Whitebeauty
    Whitebeauty New Member
    Oct 15, 2011
    5,237
    What about the Gapping? How much?
  11. TahoesHateMe
    TahoesHateMe New Member
    Mar 11, 2007
    1,115
    Where do you get your information? Been using anti sieze for over 2 decades without a single problem. German, Japanese and America engines Car and Motorcyle.
    Its great for Oxygen sensors also.
    #11 TahoesHateMe, Mar 11, 2012
  12. Murderface
    Murderface New Member
    Feb 27, 2008
    11,937
    ^^^^exactly!
    Head threads=aluminum
    Plug threads=steel
    What happens when dissimilar metals are in contact with one another? U get corrosion, this is why u need anti-seize on the plug threads. It's also a good idea to use dielectric grease on the spark plug boots so that they too don't seize onto the plugs.
  13. widdoz runner
    widdoz runner New Member
    Mar 29, 2011
    421
    does anyone know why toyota uses two brands of sparkplugs in these motors????
  14. azjay
    azjay New Member
    Jul 24, 2012
    29
    I havent found anyone or anything that has been able to confirm fact, but I've read some speculate it has to do with their supplier contracts.
    I changed mine, thanks to the write up mentioned on tw by chris, to all denso.
  15. dramad1
    dramad1 Active Member
    Mar 27, 2010
    2,367
    Gotta question, the die electric grease, do you just put a thin layer on end of plug or on bottom of coil? I am going to be changing the plugs for the first time so I'd like to get it right.
  16. Gators Taco
    Gators Taco <a . href="http://www.xr-underground.com/forum/sho
    Jul 27, 2010
    1,768
    6
    I found two different set in mine Denso and NGK. I put E3 for a change, no problem. I do have a new set I got from Gadget just in case.
  17. scareurpasenger
    scareurpasenger New Member
    Nov 21, 2012
    47
    I just ordered some ngk plugs LFR7AIX-11. One step colder and went with the ngk due to bad previous experience with denso. A friend had an electrode break on a denso and it took out his engine:( Denso may be fine but I figured I would post the ngk equivalent part number.
  18. roy365
    roy365 New Member
    Jul 21, 2008
    480
    Either one....but I usually just wipe it around the plug end instead of filling up the boot hole.
  19. roy365
    roy365 New Member
    Jul 21, 2008
    480
    P.S. Those connectors on the coils are the biggest PITA of this whole process.
  20. Fiddich
    Fiddich New Member
    Apr 3, 2012
    151
    Does anyone have a write up for a change with the Supercharger?
