SignUp Now!ok the blue wire that i unplugged desables the entire alarm system. but retains the keyless entry. anyone know which wire exactly disables the headlight
i behind the driver side kick panel there is only 1 blue wire that is T-ed.
and if it is unplugged from the alarm system, when it enters the panic mode, the headlights will NOT blink because they are taken off the system as long as the VIP stays active. if you disable the VIP the stock keyless entry/panic takes over and the headlights will blink. . . .this in all in theory tho lol
does your shock alarm go off?
and the horn doesn't beep
i pressed the door closed button, armed the alarm, and waited a bit, the took my finger off and the alarm is a no go. . . . pretty much just down to keyless entry
