Damn $1900+! I don't know anything about it but it seems to be pretty popular. Can it do things the X-1 can't?
Also sorry to hear about ur spare engine problem, did Ketchup back out of the deal or does he now need it because he blew another motor up? ROFL
Allow me to introduce myself, my name is Paul and I am one of the engineers here working on X-roller's AEM EMS. Let me give you guys a little bit of background then we will get into the nuts and bolts of it all.
We have been doing custom AEM EMS units since 2005 for various applications including: Lexus IS300, Lexus GS300, Scion tC, Scion xB, Scion xA and Toyota Yaris.
Our AEM EMS units have been used on 2 national championship cars backed by Toyota/Scion. The cars compete in NASA Enduro, WERC, Time Attack.
Anyway, enough Spam..LOL
Down to business!!!
2nd post coming with info right now.
The APR X1 was a great unit. For some unknown reason, inventory dried up.
The X1 was not a piggyback, nor a standalone. It was an in-line ECU. It worked in conjunction with the stock ECU to get what you needed for your app.
The X1 allowed for fuel trimming, rev limited adjustment, 2step and ignition trimming +/- what the stock ECU commanded.
Our AEM EMS will be complete 100% control of the combustion cycle. It will be 100% fuel and 100% ignition control. Your ball of wax 100%! No more fudging with emissions stuff and such like the X1 and others....This is pure control over the combustion cycle.
If you want to idle at 10:1 AFR and 30 degrees of advance, you can with our unit! The engine many not like it, but you can do it.
You also have control over plenty of others things like:
Up to 16 general-purpose outputs.
Up to 8 definable switch inputs.
Up to 4 EGT inputs with fuel trim.
VVT-i Control (if elected)
Anti-Lag Turbo Control (2 Styles!)
2 Step Launch Control (perfect launches everytime!)
Programmable Traction Control
Can Control Boost (with an electronic solenoid)
Definable Cut Rev Limiters
Definable Knock Control
Fuel Table Automapping
Closed Loop O2 Sensor Feedback (when used with a wideband)
Wet & Dry Nitrous Control
Individual Cylinder Fuel & Ignition Control
Can Datalog your Wideband O2 (with 5V analog input)
You can create a fully controlled machine if you set this unit up right. It will offer more than 99% of you will ever use. It will be your last EMS for sure!
If you are very hard up on tuning, you can tune EACH individual cylinder on your truck like 6 small engines. This unit can do it all. Any more Q's I will be glad to answer.
