SignUp Now!I know I tried to order the same cams through Darton right after you did Torspd, no such luck for me. When we have some one who can bring them in reliably I'll pick some up.
It is an option, depending on the time frame that you have. When APR built Paul's engine, I am pretty sure that they used Web Camshafts for their specific needs.
They were coated and very nice looking. They have done that for thousands of vehicles. Proven to work, although I can see how there could be a possible downside.
TTC Performance and LC Engineering both use Web Camshafts for their '1GR' cams.
The problem that Southernmost had with his, is as if assembly-lube was never used during assembly and start-up.
If oil or assembly-lube aren't used during assembly, massive scoring or pitting is bound to happen, no matter the brand of camshafts.
Not necessarily. I called up MoserEngineering and asked about having Toyota axle shafts made. They said to send them in. Unrelated part, but similar scenario.
Any one think of asking Dezod or URD? Since they have contacts at Motovicity.
You and I both know the demand isn't there haha.
Oh ziggity zap!!!!
Now the question is, which grinds? Only because the more aggressive grind will require a phase limiter for the intake cam gear.
ah my apology, been away from the civilian car life for awhile
