Changing tranny and diff fluid?
Im going to be changeing my tranny and diff fluid soon and was just curious how much i need and what to get? I know most are going with redline mt-90 for the tranny but what about the diff? Also if someone could do a mini write up or something on this it would be great. Im a noob :thumpdown:
NITRAM-X
Im in the same boat as you. know nothing about it but need to do it.
stretch200
lets see. The diff takes 3.5 qts. and most people use redline 75w90. the tranny take 1.9 qts.
Bobby B
The owners manual comes in handy here but the rear dif is 90w gear oil with an additive. Redline is good but Amsoil has some nice stuff too.
:biggrin:
stretch200
:biggrin:
did you use amsoil? I've been trying to find out what works. I want to use Amsoil but I don't want to be the first one to do it and then find out it'll screw up something on my X.
Bobby B
When I went to Jiffy lube the tech told me all locking rear diffs require synthetic oil with an addative. I did not change it yet I am going to wait until my next oil change. I figured even if it has synthetic already I will change it anyway. I want the good stuff :biggrin:
But I would bet that you are safe with either choice I personally am going to use Redline. But, the Amsoil would be my second choice.
I did the M/T fluid with Redline and there was a noticable difference.
the only way you screw up your XR is if you forgot to put oil in.
:top:
Spyder327
I switched to redline MT-90 yesterday, seems to work good so far :top:
