Dtlt and o2 sim questions?
babyboi2284
BaggedXR2284
I have a set of the 1st gen DTLT's and an older o2 sim (non plug and play)....when I install the DTLT's is the o2 sim the only thing I need to keep the cel light off? I know I need new crush gaskets but do I need anything else? I want to have everything before I install them.
And the 1st gen only has one bung in each header...would it be better to get another bung welded in each collector like the 2nd gen dtlts to move the sensors and use the extensions from gadget?
Lastly I will be installing a innovate wideband gauge but still have my stock y pipe. I will put the sensor in the y pipe collector...will the readings be off a lot? I've heard and read to put it in so many places....put it in the driver header, in the aftermarket ypipe collector, run two wideband gauges. I won't be doing tuning or a lot of motor mods I just want to monitor.
Detective_Dan
yes the o2 sim should be all you need. I had my wideband installed on my passenger header at the collector and I never had an issue with the readings.
think about it this way;
when you get your vehicle dyno'd, they put their afr sensor in the end of the tailpipe and it gives accurate readings. yes it is a much more sensitive system, but its still very far back from the collectors
babyboi2284
BaggedXR2284
This is the o2 sim I have. What does this do exactly? I know the stock headers have a set of cats and the DTLT's don't but you are putting the sensors back in the DTLT's. I'm keeping my stock ypipe on. The o2 sim is for the removed cats?
NHXRUNNER
"New Hampster"
It tricks the rear sensors into thinking that the front cats are still there or the ecu for that matter
babyboi2284
BaggedXR2284
Oh ok cool. I never really paid attention to the performance threads cuz I never thought I would be installing headers.
NHXRUNNER
"New Hampster"
get yourself some new manifold gaskets as well....better to be safe than sorry
NHXRUNNER
"New Hampster"
I don't.....I still need to weld in another bung on the passenger side collector so I can hook up my wraf harness extensions.
babyboi2284
BaggedXR2284
WRAF sensors on the headers and o2 sensors on the ypipe correct? I found a thread where a wideband sensor was welded on the ypipe In front of the passenger side sensor. I think that's where I may put mine
ToyotaTacoma4Ever
Will do. Do you have a wideband gauge? If so where did you mount your sensor?
I've got my wideband in the collector of the y-pipe so it can read all 6 cylinders, needed a bung welded there of course.
Your WRAF sensors will only be monitoring two cylinders if you use the bungs that the first DT have for the whole engine. For peace of mind I would get the extensions from URD and have the extra bungs in the collectors so then sensors can read all cylinders instead of just 2.
