Heat/AC loud blower motor
Well this may sound silly but when my heater/ac is on the lowest setting the motor makes a terrible clicking. doesnt do it all the time, but most. Of course when my truck was still under warranty about 2 months ago it wouldn't do it for the tech. I pulled the motor out last nite to make sure nothing was hitting the blower wheel and its all clean. Started the motor up with everything apart and thats where its coming form. (even took it apart and lubed it) The only way to fix this will be with a new motor. :thumpdown: Now my truck is out of warranty and i was wondering if you guys think they may still cover this since it was a previous issue. Heck, if they will just give me a new motor i will put it in. :hmmmm2:
plinco
i took mine in three times for the squeky blower, i just had to get stern with them to get it replaced, the noise was so bad i was going to sell the truck if it wasnt fixed.
Your telling me... so irratating :motz:
Welp... called the stealership to see what they can do about it and advised them my truck now has 39k on it and he said to bring it in and they will take care of it :top: Im actually amazed that i didn't have to argue with them or anything :rock:
wait...AC on the heat setting? man i either have my ac with full cold or my ac off with full heat if anything :top:
Ruffryder
Mine does this too. It sounds like there is a cricket in my cab! I was going to take it apart and lube it, but since you said that didn't work for you, it looks like I'll have to just take it in. VERY annoying!
Yeah... once you get everything out you can remove the cover from the motor but there really isnt anything to lube other than the two ends that the shaft glides on and i did that but it didn't help at all. :thumpdown:
