- Jan 14, 2007
- 1,769
and 07XR808 did you have to have a $25 minimum order?
thats only out of USA
SignUp Now!and 07XR808 did you have to have a $25 minimum order?
Quantity---------Product------------Price------------Options------Subtotal
1 3910-x6 LED Festoon bulb-----$ 1.95-----------White 1.75-----3.70
4 WLED 6-LED bulb---------------$ 2.79-----------White 0.95----14.96
1 dome light 3910-x6
2 map lights WLED 6-LED
2 L-plate lights WLED 6-LED
or do u think there is a better bulb for each spot
so hows the high power ones?
my gf wants to put LED's for the lic plate bulbs but i told her i no like cuz i no like the lic plate be all lit up when we pulling some robberies..haha
shoula made one switch fo turn yours off..maybe coulda ditched da POPO
i went with the high power LED one for the license plate bulbs. supposedly the brightest leds of that type...and wled-6 for the map and corner lights
if you look good thats what they are called on the website "high power"
So the 3910s do fit?
pop the plastic thing out with like a screwdriver ofr something but be careful not to scrap anything in the process. behind that should be a small metal plate looking thing, you have to pop the three sides off but be very careful cause it bends quite easily but i guess you can bend it back. Then just replace the bulb then put the metal thingy back on then when you put the clear plastic thing back on put the inner sides in first and make sure it clicks and then do the outsides and that should be all:top: hope that helpedSo is there a write up or something that shows how to remove the map light bulbs? There are no screws just melted plastic holders. How do you take the bulbs out without breaking something?
