is this small pull fast ?
TommyXrunner
hmm seems very slow to me. how hot was it when you did those pulls? heat makes a huge difference for me. i pull a lot harder with only the 2.825" pulley and full exhaust
lamia2super
Ya I'm swapping out a bad o2 sensor that was throwing the uconn off and doing some maintenance. Going to do a better video starting in 2nd gear also and maybe shift it a little faster. I baby the shifts because she grinds her gears on that hard/fast gear change(used car problems), which got a little worse after replacing the loose/broken shifter with coupe+URD shifter. Or it could just be the result of having a bad throw out bearing
