SignUp Now!front or rear? offset?
255 is way to narrow for a 10" IMO
.....but link the tire ill tell you for sure........
I got the stock 255's on 9.5. I think 10 would be be a little to far. It would be like the lowrider guys stretching a 155/80/13 over a 13x7.
not only that, but its a waste of rim. there is no need to throw the extra weight from the wider rim when the ideal rim would be aroun 8.5" for a 255 35 20 (again, it depends on the tire, but generally.......)
my 275 on my 9 inch wheel is perfectly square....just enough to able to set the wheel on the face and not hit the rim.
IMHO, for a 10in wheel youll probably want a 275 tire at least.
275mm / 25.4mm = 10.83in
for comparison 255 / 25.4 = 10.04
I love how tire sizes are a combo of inch, metric, and the wall/profile is a ratio of the width.:stupid:
yea its fuggin WHACK :motz:
i thought you were copying morcheez?
hence, 8.5" wheel:dontknow:
whats the entire size for you tires jonathan? 275x??x20 i def. need to brush up the skills in the rim department.
Do the math man its easy, on a 275/40/20 tire the 275 is width in millimeters, the 40 is the percentage of the width(275) and obviously the 20 is 20" diameter. Im going to run 20x10 all the way around, with either 275/40/20 or 295/35/20 since all the tires in 285/40/20 suck
